1952-59 Ford shot rear end!
Discussion in 'Off Topic Hot Rods & Customs' started by 2bubbas, Oct 25, 2023.
  1. 2bubbas
    2bubbas
    Just got the news that rear end ring and pinion are garbage and not available! Any suggestions?
    1954 Ford Crestliner!
  2. 2bubbas
    2bubbas
    Can get a 1956 rear complete- can't find information on width being the same-
  3. Paul2748
    Paul2748
    As an example, I put a 57 rear in my 54 and they were the same length.
    If you have a sedan with the drop out center section, the 56 center section may go right in.
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    The track width is the same and uses the same rear U-joint, EZ swap, but check the brake drums they can be hard to find and $$$. You might want to check the "Sticky" and do a Ranger Rear swap parts are more available and a lot less expensive and will have self adjusting brakes.
    Texas57 likes this.
