Should I straight axle it?
Discussion in 'The Hokey Ass Message Board' started by jimbob, Nov 25, 2004.
  1. jimbob
    jimbob
    Even though this shot is photoshopped, my bucket is nearly done. Its at the trimmer now, and my WWW slicks and front firestones showed up yesterday. It will run straight open pipes off the heads, moon chrome air filters, old Cal custom finned alloy valve covers, and black steelies. Question is, should I whack a straight axle up front??????
    Thanks in advance for your opinions.
    Cheers and beers
    Jimbob
  2. Rocklock
    Rocklock
    I wouldn't, but it is your car so go ahead. Hell, you can change it back.
    Now a 40 ford coupe w/ a 427 side oiler would me a great straight axle g***er.
    Rocklock
    '56 Victoria
  3. Dirty2
    Dirty2
  4. ratster
    ratster
  5. naw wrong type of car its got a tube now right ? nose high rdstrs only work on F/A's
  6. Rusty
    Rusty
    that is one cool bucket
  7. Jimbob,
    No if you ask me, but as said....its your set of wheels [​IMG] !!!
    That's a fine looking T you've got there....I wouldn't change it....better start the next project... [​IMG] [​IMG] [​IMG]
    / Sven
  8. HOTRODPRIMER
    HOTRODPRIMER
    Nothin' wrong with it now,,,,,start a new project! HRP
  9. jimbob
    jimbob
    Is running a standard chromed 32 I beam at the moment. Was thinkin of pickin the front up like an altered [​IMG].
  10. looks completely right ,just the way it is , a chromed I beam is way cooler than a nose bleed stance in a car like that-JMO
  11. Fat Hack
    Fat Hack
    from Detroit
    If you run zoomies, an empty grille shell, moon tank, wrinkle walls on Halibrands out back with twelve spokers up front, a driver cage and a 'chute...yes!
    If not, keep it like it is! [​IMG]
