Technical Should I use a residual valve?
Discussion in 'Traditional Hot Rods' started by chris101_ny, Oct 6, 2024.
  1. V8 Bob
    V8 Bob
    Mr48chev, air should not be entering any drum wheel cylinders during non use that are in good condition. The only time this may occur is during rapid brake release, when fast piston movement (caused by shoe strong return springs) can pull air past the seals, and is what residuals and cup expanders prevent. The entire brake system should normally remain air tight.
    I have 3 cars with under floor dual masters with internal residuals and have never had any air problems.
  2. MOONRNR
    MOONRNR
    RICH B likes this.
  3. twenty8
    twenty8
    It has to do with "spreading ****er with a machete", but I'm not sure you will entirely understand the concept.
    Why didn't you bother to give an explanation like this in the other thread??? You obviously know your stuff, but it seems that you are not always in the mood to help people out. Instead, out comes the machete.o_O
    As for noone calling out the other guy's post, if you go back and check you will find that I stated that you were correct about the seals returning the pistons away from the rotors.
    And it really is time to get rid of the signature line. It says more about you than it does about anyone else.....;)
    2OLD2FAST and Sharpone like this.
  4. 1971BB427
    1971BB427
    from Oregon
    No reason for residual valves at any axle if the master is the highest point. Car makers didn't use them, so why do people put them in today when they build?
    Neither of my cars have residual vales with disc/drum setups, and my last build was drums all around and I plumbed them without residual valves. All of them stop great and no pedal height issues.
    skooch and 2OLD2FAST like this.
  5. 57 Fargo
    57 Fargo
    This is only correct if the wheel cylinders have cup expanders in them. There’s a reason why oem drum systems used one or the other.
    Car manufacturers did use them!
  6. MOONRNR
    MOONRNR
    That is not the problem. The poster stated this and by now should know he was incorrect. Have you seen an apology? Maybe he IGNORED me (whoopty-do) and has not either realized/ corrected his post and/or apologized (not that it matters to me). He is still posting.
    Do you now understand how all of this disinformation keeps getting spread?
    It seems maybe I have awakened a few and the facts are starting to be pointed out. This thread has taken a new direction.
    BTW - I am here to pick-up knowledge, not win a popularity contest.
  7. 57 Fargo
    57 Fargo
    As much as I may not agree with @MOONRNR approach, I can relate to the frustration of seeing outright wrong information about brakes over and over and over again.
  8. 2OLD2FAST
    2OLD2FAST
    from illinois
    If you're planning on correcting all the dis-information on just this forum , you really need to roll your sleeves up . Simply say that's not true & be done with it , life's waaaay too short
  9. twenty8
    twenty8
    Yep, I get where you are coming from......... just don't agree with the way you go about it.
    And, as for this.....
    ...... there is no danger of that happening.....:rolleyes:
  10. jimmy six
    jimmy six
    I know your car guys and good ones but why would you drive and do a photo shoot with a sticking throttle or “needing to ride the brakes” that’s insane.
    Sharpone and twenty8 like this.
  11. MOONRNR
    MOONRNR
    Why would a novice that comes here seeking TECH KNOWLEDGE, be given incorrect info and others swear by it?
    It can lead to the same situation(s).
    The COMET owner up-graded the power of the car and did not check or upgrade the brakes (previously modified but out of current tech and not up to the power upgrade).
    I bet he learned to do it correctly after that.
    If one modifies a car incorrectly and busts his a$$, that is one thing. You involve innocents and that is another.
    You are giving the hobby a bad name and drawing the wrong attention.
    As for the SIGNATURE, that stays. He treated me in a similar fashion.
  12. chris101_ny
    chris101_ny
    I meant no malice and accidentally replied to the wrong thread. trying to joke about it bc whats the point of being negative, it really serves no purpose. We're all just filling our time, whether it has a very specific purpose or for mild entertainment by just reading about hot rods. I was actually I have some clue, but no where enough that I can get through it without ***istance. I absolutely appreciate all of the ***istance I am offered, this time and any other time I have sought it in the past!
    Sharpone and Budget36 like this.
  13. chris101_ny
    chris101_ny
    I meant no malice to anyone! Just trying to joke about it bc what's the point of being negative, life's too short. We're all just filling our time, whether it has a very specific purpose or for mild entertainment by just reading about hot rods. I actually have some clue, but nowhere near enough that I can get through it without ***istance. I absolutely appreciate all of the ***istance I am offered, this time and any other time I have sought it in the past!
  14. Budget36
    Budget36
    I didn’t take anything you said as malice. Personally I thought you were diffusing things.
    chris101_ny and Sharpone like this.
  15. MOONRNR
    MOONRNR
    You need to turn your reverb off ...
    chris101_ny likes this.
  16. MOONRNR
    MOONRNR
    ORIGINAL THREAD - https://www.jalopyjournal.com/forum/threads/another-master-cylinder-question.1320288/
    And I am wrong for calling him out? He most likely has me on IGNORE as he has not admitted here that his brake theory in incorrect and actually down right dangerous. Shows his character.
    You can also see the heroes that agreed with him
    Now maybe you will understand the at***udes on this forum and the constant misinformation being given.
  17. MOONRNR
    MOONRNR
    Because the man is a MOE-RON and most likely got his understanding of BRAKE THEORY here.
    The reason(s) for the failure are obvious.
  18. MOONRNR
    MOONRNR
    Uh ...
    Yes, car manufacturers did use them.
  19. twenty8
    twenty8
    Turns out you were correct about this as well......
  20. MOONRNR
    MOONRNR
    Just another exciting installment of -
    THE H.A.M.Bone 'WILLY STOP' BRAKE THEORY​
  21. TubT
    TubT
    from Texas
    I'll go you one better. Even if the master cylinder is lower than the brake cylinders (or calipers), once the system is properly bled, there's no reason that air would enter the lines from the brakes to the master cylinder. Remember the experiment we all conducted on our milk in the elementary school lunch room? You put your straw in the milk carton. You put your finger over the top end of the straw. You pull the straw up from the carton, and the milk stays in the straw. (If you're really the brave sort, you held it up, removed your finger, and caught the escaping milk in your mouth, impressing the other 3rd grade boys and grossing out the 3rd grade girls at the table.) The carton is the master cylinder. The milk is the brake line. And your finger is the wheel cylinder or caliper. Unless air enters the wheel cylinder/caliper, no fluid flows back to the master cylinder, except that displaced with master cylinder pressure.
    patsurf likes this.
  22. Jmountainjr
    Jmountainjr
    Do you know what residual valves, or not, that your "Corvette style" has? I would start there before deciding what you may / may not need.
  23. 427 sleeper
    427 sleeper
    I'm probably wrong and definately confused, but why would the dual chamber Corvette M/C's EVER be equipped with residual valve's, being that they were only used on Vette's with 4 wheel disc's? Just don't make sense to me.
