Should i use new head bolts?
Discussion in 'The Hokey Ass Message Board' started by magsnubby, Sep 18, 2010.
  1. themoose
    themoose
    I agree...............
    Beam or Needle Torque Wrenches
    This type of torque wrench looks like a sword, with the ****og pointer scale being the handguard.
    The beam or main body of the wrench is designed to bend under force. A separate needle pointer stays straight and indicates the torque on the scale.
    Advantages
    • Simple and reliable, proven design. Almost no moving parts, nothing to jam and cause over-torquing.
    • Can measure torque in both directions.
    • Can measure torque from zero to the maximum rated torque.
    • Accurate, as high as 2 percent accuracy.
    Disadvantages
    • Needs some maintenance. The beam sometimes stays bent and needs to be straightened to zero the scale.
    • Scale needs to be watched all the time to see when the correct torque is reached.
    Useful features
    • Sliding tabs to remember the maximum torque achieved. This allows measurement of the torque needed to loosen a bolt. The same amount of torque can then be used to tighten back the bolt.
    • Some wrenches come with calibration certificates.
    How to Calibrate a Torque Wrench
    Commercial calibration services are available for torque wrenches. Rough and simple DIY calibration is also possible at home:
    • A beam wrench can be used to calibrate a click wrench. A bolt is tightened with the click wrench. The beam wrench is then used to tighten the bolt again. Before the preset (on the click wrench) torque is reached, the bolt should not move. After the preset torque, the bolt should tighten up some more.
    • A bolt is firmly clamped to the workbench. A torque wrench is fixed to the bolt parallel to the floor. Weights are hung from the wrench handle. The torque is calculated from (weight) x (distance of weight on handle from bolt). This is compared against the indicated torque (beam wrench), or weights are added until the wrench "breaks" (click wrench). Care should be taken as the sudden release of the weights can cause injury.
    The Best Torque Wrench
    For most DIY home mechanics, a simple and affordable click torque wrench is easy to use and accurate enough. A beam torque wrench is a useful addition for the lower torque ranges, and its simple reliability means that it can be used to roughly calibrate ("sanity check") click wrenches.
    Oh yeah By the book the head bolts don't need to be replaced but the Engine cost (X) bolts cost (Y) you decide
  2. Energy
    Energy
    I was told that the only ones you need to replace every time are the new design ones with the reduced diameter shanks between the heads and the threads. Is what I do at any rate.
    :confused:
  3. str8axle55
    str8axle55
    from MA
    X2, never had an issue re-using SBC head bolts, make sure the threads are clean in the block and on the bolts.
  4. Ahhh, those thing are like 45 years old, aren't they?
    And they hold back maybe what, 10 1/2 or maybe 11:1 compression?
    How long do you want it to run for?
    And what about your rod and main bolts? You chucking them too I hope?
  5. I never knew that! I was always told to use new bolts at all times!
    But I'm not going to screw with THE Squirrel on something like this!!
    Doc.
  6. brad chevy
    brad chevy
    Hes not working on a Toyota,its a American made engine and just cause the bolts are 45 years old don"t mean ****.
  7. mustang6147
    mustang6147
    from Kent, Ohio
    This always a hot topic, but it all boils down to a few things. How are the threads? How do the bolts look? and now with all the different opinions, can you put it together without any concern after reading all the different opinions.
    I use ARP in my racing engines, but have used stock bolts on normal freshen ups. There you have it, 1 more opinion
  8. magsnubby
    magsnubby
    from Fresno,Ca
    The bolts are 45 years, 7 months, 14 days, 37 hours 3 minutes and 37 seconds old. Compression ratio will be 25:1. I want it run trouble free for 850 million miles. I'm not using rod or main bolts i welded everything together. I think i'll just say screw the head bolts and weld the heads on also. Then i won't need to waste my money on a torque wrench.
  9. nummie
    nummie
    I try to use new when its possible, and besides the old bolts are good for welding gussets and reinforcing the kids' go kart.
  10. Baron
    Baron
    Same thought here ( and I have done it a hundred times, and not once had a problem). And there is nothing wrong with installing a new set ARPS,but certainly not necessary. Good luck with the 327. Great motors!
