Should you balance gasser wheels?
Discussion in 'The Hokey Ass Message Board' started by pearl31, Feb 1, 2013.
  1. pearl31
    pearl31
    Just got the tires in for the launcher wheels from Rocket. My Discount tire store just has non chrome stick on weights so the question is with 155 60/15 tires would you normally balance these rims and tires knowing there might be a blemish?
  2. FiddyFour
    FiddyFour
    try tire beads... get the balance without the weights
  3. hotroddon
    hotroddon
    I know on my "G***er", if one of the fronts is out of balance at a buck fifty you sure as hell feel it
  4. langy
    langy
    Definitely get them balanced without a doubt !!!, you can put the weights on the inside.
  5. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Why worry about balance, its just a high speed vehicle? YES balance them
  6. black 62
    black 62
    from arkansas
    balance them
  7. Naw tire shake on the big end is cool doesn't matter if it is a front or a rear. :rolleyes:
  8. Balance any wheel if your gonna drive it over 10-15 mph.
  9. NEWFISHER
    NEWFISHER
    from Oregon
    Make sure its done on a traditional bubble balencer :)
  10. Beau
    Beau
    If it's a g***er set up just for idling around car shows, no.
  11. Chrome wheel weights!?!? [​IMG]
    Seriously? :confused:
    [​IMG] What the **** is this place coming to?
  12. fordcragar
    fordcragar
    from Yakima WA.
    If it doesn't go any faster than going on or off the trailer, no need to balance them.:D
  13. Beau
    Beau
    Can you polish or chrome lead weights?
  14. rustednutz
    rustednutz
    from tulsa, ok
    Yeh, you can use that spray on chrome paint, but then you would have to rebalance. Then you spray your new added weights, but then you would have to rebalance. Then you spray -----
  15. [​IMG]
  16. Wheel weights 7 gram stick-on in Siver, Black, or Chrome available at J.P. Cycles, all you have to do is ask me, :D TR
  17. Can't get home.......without the chrome..............:cool:
  18. Mr48chev
    No! Absolutely not! I balanced thousands of tires over the time I worked in tire shops and did front end work and spent many hours getting vibrations out of cars for very picky customers and while a bubble balancer is "traditional" it won't get the job done on a car that will hit 100+
    Spun balanced by someone who really knows what he is doing with a good machine is a lot better. Spun balanced on the car with a strobe balancer and someone who really knows what he is doing is a hell of a lot better.
    And why would you even consider not balancing the tires unless it is a trailered fairgrounds poser that will never get driven on the street or track except to and from the power parking spot.
  19. DFH-GMC
    DFH-GMC
    from Texas
    Only the rears front should always be in the air
  20. Mat Thrasher
    Mat Thrasher
    I mount my tires myself and never balance them. Truthfully I don't think you'll be able to feel much of a difference. Obviously we're talking about hod rods, not brand new Caddies. But maybe I'm just a trailer fairground poser and I've never had my truck anywhere near 125.:)
    That's just my experience I'm not saying you shouldn't. But I've never had any issues.
    PS I never balanced any of my drag/street bike tires and I was running mid 9's @ 150.
  21. Dane
    Dane
    from Soquel, CA
    Death wobble while going through the traps at the track or anywhere on the street would not be fun. Could get expensive. Get them balanced...
  22. Olderchild
    Olderchild
    from Ohio
  23. kscarguy
    kscarguy
    don't balance them..then the car will look like a cartoon as each wheel bounces up and down off the ground.....just like on Roger Rabbit! wheeeeee
  24. I concur! I even have the front tires trued.
  25. R Pope
    R Pope
    A tire that needs a big weight to balance goes back on the rack if it was for any of my cars! There's something wrong with the construction if they are very far out of true, like more than a small weight needed. Even balanced, they will come apart at prolonged high speeds.
  26. Redtex59
    Redtex59
    Find a good shop with a Road Force balancer. They should be able to match mount the tire and wheel and even hide the weights behind the spokes.
    But, DEFINITELY balance.....
    Painted chrome wheel weights? Really????? Wahahhaaa
  27. usmc50lx
    usmc50lx
    from St.Louis
    Must be Cokers.........:rolleyes:
  28. BobMcD
    BobMcD
    By all means check the balance. See if your tire shop can do a match mount as redtex59 suggested. They will check the balance and try to match the heaviest spot on the tire with the lightest spot on the rim to use the least amount of weight. You might be able to get to get by with no weight at all if your lucky, or at least get it close. The tire will need to be broken down a couple of times and rotated on the rim to get it right. Not all tire shops would be willing to take the time to do it though. IMHO it's not the equipment used but the guy using it that will get it right.
