Shoulder harness without a rollbar?
Discussion in 'The Hokey Ass Message Board' started by 37_chevy, Feb 19, 2013.
  1. 37_chevy
    37_chevy
    from Nebraska
    I'm building a '56 Chevy g***er. It will see a little track time, but mostly a street machine. I don't want to run a roll bar with a bar behind the front seats as it would make it hard to get people in the back seat.
    Is there a way to attach the shoulder harness to the floor? Does anybody know who makes a set that would be long enough to reach from the floor, over the shoulders and back down to the lap belt?
    Thanks for your ideas!
  2. dirt t
    dirt t
    If you attach your belts to the floor in a crash it will compress your spine and maybe break your back. The shoulder straps should be 90* to your sholders. Not safe the way you are looking at doing it.
  3. stuart in mn
    stuart in mn
    Shoulder harnesses shouldn't be attached to the floor - in the event of a crash it will pull down on your body compressing your spine. It needs to be attached at shoulder level or maybe slightly below, to a roll bar or cross bar. You may be able to run a connecting strap back to the package tray, if you can get a good solid connection point there.
  4. 37_chevy
    37_chevy
    from Nebraska
    I didn't think about it that way. Maybe they'll just have to crawl over the roll bar.
    Thanks!
  5. you can have a removable cross bar.
  6. black 62
    black 62
    from arkansas
    how fast is it going to be ---might not need one...
  7. SimonSez
    SimonSez
    Yep, I have one in my Sedan that bolts in across the main hoop.
    I leave the shoulder belts permanently on it and just put it in when I am racing as there are 3-point retractable belts in it for the street.
