Show me your....Fire wall recess
Discussion in 'The Hokey Ass Message Board' started by so-cheap, May 3, 2004.
  1. so-cheap
    so-cheap
    I have heard lots of things lately on firewall
    recesses. From Little red wagons to Wheel barrows.
    What have you done?
  2. flt-blk
    flt-blk
    from IL
    My TurfMaster 2000 gave it's life for my firewall, the back
    radius was perfect, I had to widen it 3".
    I used the front portion with a little more work for a
    transmission tunnel.
    I'll find a pic tonight to post.
    TZ
  3. Here is a Speed Center firewall I adapted to my T. Yes, I am using a supe flat ****** to fit under it [​IMG]
  4. my old sled..
  5. OGNC
    OGNC
    I used the front corners of a cheap home-depot wheel barrow for the firewall on my old f-100. It worked out pretty well.
  6. Dirk35
    Dirk35
  7. KCMongo
    KCMongo
    from KC
    My firewall on my 51' Extended Cab Chevy.
    The measurements on the bowtie are setup so the big block will sit back into it nicely, will need to cut the trans tunnel still once we get it all mocked up and figure out how much we have to cut.
    It's been done a couple years, a sheetmetal worker buddy of mine did the work as I didn't have the necc. tools or know how to do it back then.. (Still don't)
    ****O
  8. Paul
    Paul
    Editor
    trimmed 5" and tunneled another 5" for 10" total recess..
    used 1/4" aluminum plate for firewall.
  9. Paul
    Paul
    Editor
  10. KCMongo
    KCMongo
    from KC
    Anybody used pieces from a 50 Gallon Drum, I've got one sitting out at the farm next to my other project and was thinking it could make a slick setback, Haven't started hacking on it yet, gotta go dump it in the ditch first.
    ****O
  11. Boones
    Boones
    from Kent, Wa
    I dig when the entire firewall is pushed in and only a slight edge remains. its a nice clean look rather then just a square hole.. thou I have seen some nice examples of those also.
  12. el Scotto
    el Scotto
    from Tracy, CA
    You guys are great! I was just looking at my firewall, and was thinking about how I should set it up, and wah-la!! Next day, on the HAMB.... [​IMG]
  13. Here's my "TruValue 39.95 universal firewall kit"(TM) Some ***embly required!
  14. Here's a shot of the finished product.
  15. hdv32
    hdv32
    Anyone have pictures of a 30 or 31 ford stock firewall reversed to gain additional space. The question is whether I could get enough space for a SBC. I know I would have to trim for the ******. I am not sure how the bottom near the toe board would work or look. Car is a 31 coupe on 32 rails, with rear wheelwells centered on stock 106 inch wheelbase.
  16. QQMOON
    QQMOON
    If you can see it clear enough I have reversed another 31 firewall behind the original looks ok and finished up well
    JR
  17. Bob K
    Bob K
    from Antigo Wi.
    Just plain ol flat sheet metal.
    Before
    After
    B [​IMG] B
  18. Toqwik
    Toqwik
    on mine I cut the orig firewallout, left bout an inch all the way around, bent up some metal, formed it to the radius of the cowl, welded it in, voila, no body work needed...Toqwik
  19. flt-blk
    flt-blk
    from IL
    Tinbender and I shop at the same place.
    TZ
  20. flt-blk
    flt-blk
    from IL
  21. flt-blk
    flt-blk
    from IL
    Ready to be welded in.
  22. ChuckleHead_Al
    ChuckleHead_Al
    What a bad *** idea! Wow never though or heard of that, it's cheap in the pocket and looks great, thanx i'll use that, on my t-truck
  23. so-cheap
    so-cheap
    Awesome guys. Very nice work. Thanks for the input.
  24. hunter lake
    hunter lake
    Bob, what are you doing for w/wipers on the 52 ?
    I am working on a 53 and love your firewall .......
  25. Here's the standard Brookville 4" recess.
    As you can see it's not quite big enough for the 455 Buicks so it gets widened a bit.
    You guys ought to go to DRD57's site and read his step by step on a wheelbarrow firewall on his SBC powered coupe.
    The wheelbarrow firewall is about three times cl***ier than the simple recess on my 31.
    Don's Firewall
  26. fleetmaster
    fleetmaster
    i went with the wheel barrow too-works pretty good and looks nice too
  27. How did that work out with the big block? Did you have to make it wider
  28. staleg
    staleg
    Before modification starts.
  29. staleg
    staleg
    During the modification
  30. staleg
    staleg
    Finished
