Hey guys I'm trying to install a mustang radaitor and 32 grill shell in my 24 c cab need some help on the brackets so if you bucket owners with a mustang radaitor can take some shots of your brackets and send them to me I whould be thankful. little short on brain power now and then. thanks
This is not exactly what you want, but it may help. The bracket has several holes for height adjustment and it would be easy to drill the horizontal piece longer and with a few holes so it could be adjusted longitudinally. In this case, the bracket was used to set the height for a Deuce grill shell on a 31 on 32 rails roadster project. You could do something similar and make the vertical run out of angle with one leg of the angle fairly short. Something along the lines of 1/2 x 1 x 1/8" cut to the required height. Aluminum would work well and it's already finished. Steel would work just as well. As far as fore and aft bracing goes, a pair of rods similar to what A's & Deuce use could be used. If you're running hood sides, 1/2 x 1" rectangular tubing to brace the radiator also gives you a good place to hang your hood sides.
