Show Us Ya Motor
Discussion in 'The Hokey Ass Message Board' started by HotRodGuy1932, Nov 23, 2008.
  1. Plan9MaxWedge
    Plan9MaxWedge
    from Tipp City
  2. Thought you guys would like another few pics of "RatBastad". Pic was taken at the little town of Bright in Victoria Australia in 2007. I was rolling with the "Cherry Bombers" which have since grown to about 20 members. Enjoying these kick **** motors man there are some big motors here and some really interesting ones to. Keep it up guys.:)
    I have wanting to paint my five window this color for years now i have seen it on this 32 looks good. Just got to get the mix right so many blues it gets confussing. Wouldn't want to help me out with the color"Rat Bastad":):)
  3. Hi Guys,
    This one is my mates at the bright rod run in 2007.
    And a sled pic is a ring in just thought you guys would like to see what some Aussies are doing down under. Metal finished and then clear coated note the pin striping on the front very suttle.:D
  4. Beautiful, "simply" beautiful, lotsa nice odd motors shown so far.Peace,,,Moosie :)
  5. tmacracin
    tmacracin
    Here is my 355ci SBC for my 28 pickup and my 470ci BBC out of my altered
  6. chevy57dude
    chevy57dude
    Hey Wingnutz nothing boring about Olds power,especially dual quad equipped in a roadster! 455 olds has a longer stroke than a 454 Chevy, all that torque no way you can keep tires on that rod! WAY cool!
  7. krackerjack88
    krackerjack88
    from Fresno,Ca
    216 baby!
  8. krackerjack88
    krackerjack88
    from Fresno,Ca
    Then my 454
      101.3 KB
  9. HemiRambler
    HemiRambler
    My latest motor literally made from pieces parts laying around the garage and hemi "junk" I have scavenged over the years. 9.66 @ 137 - which I am thrilled with considering what it is.
  10. BloodyKnuckles
    BloodyKnuckles
    1951 Plymouth 218
    ******Knuckles
  11. Sweats
    Sweats
    fresh from the machine shop on Monday!..droppin her in tomorrow!
  12. OoltewahSpeedShop
    OoltewahSpeedShop
    Boss 351 Cleveland in my shop truck. Merc Flatty thats in my little '23 roadster truck.
    Later,
    Kevin
    Ooltewah Speed Shop
  13. '60 tripower 348 chebbie. Goes like stink!
  14. tmacracin
    tmacracin
    Looks good! What are the specs?
  15. Rocky
    Rocky
    Classified Editor
    It ain't much yet...goes in my 34, 5 window..
  16. Thunder Road
    Thunder Road
    Here's mine- '36 block, 3/4 cam, bored .060, aluminum flywheel, 2 dueces on a Fenton intake and Eddie Meyer heads.
  17. HemiRambler
    HemiRambler
    Thanks, The motor is near stock - just a few small upgrades for durability. .030" over 392 - stock crank - stock rods (ARP rod bolts) - 10:1 cast pistons - stock oil pump I blueprinted and slightly modified - integral pickup and dropped down. Stock 331 heads - other than I cut them for bigger springs and I step drilled the pushrod holes for 3/8" pushrods. Stock valves - no porting - no polishing - no gasket matching . I did remove the combustion chamber "edge chamfer" making these resemble 392 heads (a mod I would have rather NOT done but they'd hit the pistons otherwise). Smith Brothers moly pushrods - vintage set of Gotha rockers. Mild Hydraulic Cam - stock timing chain that I adapted to run the hilborn pump using a chevy drive spud. Bottom end girdle that I bought 20 years ago for s**** - it's definitely not needed on this motor, but I was planning ahead and fitted it now rather than later. I did fab the pan and windage tray as well as adapted a tilton starter. Vertex mag - hilborn injector - both Ebay/Internet items. I rebuilt the hilborn injector and pump - I aksed lots of questions as this was all new to me. Matter of fact I purposefully built this motor on the mild side as this was my first Front Engine Dragster. TCI Powerglide (Ebay) and 3500 converter. 9" rear I built from all Strange pieces less the pinion support - a somewhat rare 4 bearing support - makes a daytona support look like a weakling. 3.89 Pro gear - wilwood brakes -Twin Simpson air brake. I digress.....:eek:
    EDIT: The NEXT motor I will get a little more serious with - eventually stuffing a 6:71 on, but for now - we've got our hands full learning with this one!
  18. tmacracin
    tmacracin
    HemiRambler
    Sounds like a good setup.I'm just in the middle of building a blown 392 for a friend I will have some more info and pictures of it soon
  19. blown49
    blown49
    Been on here before, my Merc flathead motor:
  20. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    DeathsDoorSteps Motivation........392 Hemi .060'' over......11-1 Ross Forged pistons, BillMiller Aluminum Rods, fully balanced ***embly, Solid Isky Stick/Solid Lifters.......good oiling system...Nicson front Timing cover/ Mount.....354 Heads w/ Aluminum Valve Covers, ''O'' Ringed w/ copper head gaskets, ADJ. Rockers, 2 1/16'' Intake and 2 1/16 Exhaust Valves, Ported just like the old Mondello's w/ heat risers welded plus and handful of more tricks done to them......DragStar 6X2 Intake ported to match the Heads w/ Six 94 Carbs on top...I blue printed each carb and severly violated them, they flow plenty...All fire and noise is stired up by a MSD Dizzy......My rule of thumb to building a Early Hemi is.....once your done.....its first name should not end up being Nancy....................Littleman
  21. Ontario55
    Ontario55
    Blown 355 Cu in
  22. B/B Ford
    B/B Ford
    1970 Lincoln 460
  23. Kerry
    Kerry
  24. gkgeiger
    gkgeiger
    The engine in my 65.
  25. JeffB2
    JeffB2
    from Phoenix,AZ
    302 Ford in my '54 Customline:cool:
  26. krazydeuce
    krazydeuce
    from Hawaii
    327 chevy w/little helpers.......:D:D:D
  27. Tudor
    Tudor
    from GA
  28. 35 Dodge Hot Rod
    35 Dodge Hot Rod
    from Mecca
    The engine on the left is a 60's 318 Poly with my 6-71 blower setup mocked up on it. It'll eventually take the place of my factory 1957 dual quad 318 Poly on the right in my 1935 Dodge pickup.
  29. BigBlockMopar
    BigBlockMopar
    496ci, 4.15" stroke crank, H-beam rods, 10.5:1cr Diamond pistons, balanced ***embly, Edelbrock heads, long ram intakes, solid lifters (soon roller), 1.6 rockers, dual 625 Carter carbs...
    I'm also building a '57-392, bored .020" over.
    Will receive a Weiand dual quad intake, stock internals 'cept for a 2 steps 'bigger' than stock cam.
    Currently at the machine shop is another 4.15" stroke 496" block. It's being bored, decked, balanced and linebored&honed. 9.2:1cr dished Ross pistons, H-beam rods, 0.120" Cometic gaskets, Indy 440-1 heads, 0.630" Roller cam.
    This engine will be topped off with a 8/71 Kuhl supercharger...
    Temp mock up pic;
  30. Ice man
    Ice man
    This is my B ready to go in the 29. Running a T-5 trany and open drive to a Model A rear.
