Technical Show Us Your Fabricated Parts
Discussion in 'The Hokey Ass Message Board' started by Speed Gems, Mar 29, 2018.
  1. rusty rocket
    rusty rocket
    IMG_1773.JPG IMG_2506.JPG Threw together this front crossmember.
    brEad, loudbang, bct and 1 other person like this.
  2. Jiminy
    Jiminy
    loudbang and Hackerbilt like this.
  3. strait8
    strait8
    from Skokie, IL
    Rich that is just unreal! Can you make a head for us Straight Eight Buick guys?
    Bones....phew... you had me worried! I thought I was gonna learn that the Ni-Copp I used was a bad choice for some reason I did not have knowledge of. Local car parts place turned me on to it. Says for brake lines on it. If I recall it was ok for fuel too. Hope so cause I did that too. It was easy to work with and I liked the look of it. Most of all when I got the car I had to re-do all the lines so there was a lot of bending. Worked well with drums all the way around for several years until the master died. Guess we'll see with the power discs this summer. So far so good.
  4. RichFox
    RichFox
    I never finished this one. Well the head was pretty much finished. Engine needed new pistons and reassembly. I would never start anything like this now. It was hard to get out in the shop a couple of years ago when we did this. It's the kind of thing you need to do yourself. Pull the trigger and buy a mill and just start. Keep going and eventually you will have a head. PS. You do know the Salt Cat guys in Montana converted a stock Buick head to 16 ports using a drill press they say. Now that I think of it. There was a lakester at Bonneville with a Buick eight and a head made using four Subaru heads. Really neat. You can do it if you stop thinking you can't.
  5. I understand Kunifer/NiCopp is not widely used in the USA so not surprising you haven’t heard of it previously. Looks like copper so would certainly ring alarm bells for those used to using steel. It’s great stuff and worth a try next time you do brake lines
  6. chubbie
    chubbie
    well... lets see yours!
    williebill, Hackerbilt and loudbang like this.
  8. Hmm, I bet Autozone stocks those. Is that with or without Air Conditioning? 2 or 4 wheel drive?
    Actually, thanks for the photo, gives me something to think about.
    deathrowdave and loudbang like this.
  9. SNS FAB
    SNS FAB
    Here is a spacer I made to raise a supercharger up. Started with a 18" x 18" x 1 1/4" thick chunk of aluminum. BLOWER SPACER.jpg BLOWER SPACER 2.jpg
  10. RichFox
    RichFox
    Rather large pump there 14-71 or 18?
  11. 40ragtopdown
    40ragtopdown
    20180401_155743.jpg 20180401_160125.jpg 20180402_131440.jpg 20180404_103709.jpg 20180404_104552.jpg center brace for 40 ford frame.
  12. SNS FAB
    SNS FAB
  13. Marty Strode
    Marty Strode
    Bolt in rear radius rod mounting, 35-40 Ford. IMG_3161.JPG IMG_3164.JPG IMG_3165.JPG
  14. Capitan Freddy
    Capitan Freddy
    Home made open drive conversion on a Model A banjo rear end. IMG_20170224_203738218.jpg
  15. bobbytnm
    bobbytnm
    Years ago I fabbed a new rear bed crossmember for my 49 Ford truck. I used some pre-stamped bed pockets, some rectangular tubing and some round tubing and fabbed the rear rolled piece across the rear of the bed.
    brEad, charleyw, williebill and 3 others like this.
  16. bobbytnm
    bobbytnm
    I also fabbed up some valve covers for my big Caddy by mating some early 50's valve covers with the late model stuff;
  17. atch
    atch
    I like how these turned out.
    dana barlow and loudbang like this.
  18. bobbytnm
    bobbytnm
  19. RichFox
    RichFox
    I took the easy way out. Drilled and tapped fender script #2-56. And screwed them to the covers img96.JPG
  20. Welcome to the HAMB, Captain Freddy, that's a great candidate for a Technical thread on its own. Do you have more pictures?
  21. Capitan Freddy
    Capitan Freddy
    Thanks. I do have more pictures and part numbers. I will put it all together soon.
    King ford, loudbang, bobbytnm and 2 others like this.
  22. williebill
    williebill
    Amazing craftsmanship all over this thread, as usual. You guys are good.
    loudbang and 31Vicky with a hemi like this.
  23. bobbytnm
    bobbytnm
    I'm looking forward to it as I'll have to tackle the project sometime this year....(hopefully)
    I just noticed that you are in Alb. I'd love a chance to see your toys
  24. Got thr real brackets back.
    Roughing out a custom hub on my toy lathe.
    There's a pile of chips ass high
  25. Capitan Freddy
    Capitan Freddy
    Sounds good. I would like to check out that RPU you are working on.
  26. r2c1
    r2c1
    Exhaust I did for a 40 Ford Sedan Delivery. Owner wanted both exhaust run on right side.
  27. lostone
    lostone
    from kansas
    Never found a spreader bar I liked so I built this one for the model A frame I scratch built. My bar is about 75 to 80% done.
  28. I bet this part was fun !
    Looks good, nice job
    fauj, Hackerbilt, r2c1 and 1 other person like this.
  29. cederholm
    cederholm
    Best thread on the HAMB! You boys do impressive work. Loving all of it.
    ~ Carl
  30. 2NDCHANCE
    2NDCHANCE
    IMG_0415.JPG LARRY-1.jpg We took a nice 1930 Model a body and added a rear door. All custom fabrication, pattern making 101 IMG_0410.JPG
