Hot Rods Show Us Your Fuel lines
Discussion in 'The Hokey Ass Message Board' started by Speed Gems, Aug 13, 2015.
  1. Speed Gems
    Speed Gems
    Remember the scene in American Graffiti where Millner is tuning up his engine for the big drag race with Falfa? You can see the clear fuel lines running to all carburetors. Show us the fuel lines on your multi carb manifolds clear, colored plastic, Copper, etc.
    Max Gearhead likes this.
  2. Speed Gems
    Speed Gems
  3. KFC
    KFC
    from UK
    I had the red clear fuel line on for 48hrs before it went soft and the petrol went red
    Ended up with a more industrial set up
    Speed Gems likes this.
  4. Gene Boul
    Gene Boul
    Speed Gems and Turnipseed like this.
  5. Atwater Mike
    Atwater Mike
    Hot combo...Red plastic hoses going to a brace of Stromberg Firepots.
    Hilo hotrodder likes this.
  6. Clear Tygon, good stuff! Tygon® Fuel and Lubricant Tubing resists the swelling and hardening caused by hydrocarbon-based fluids. This significantly reduces the risk of failure due to cracking and leakage.
  7. Speed Gems
    Speed Gems
    The ethanol may do a number on your carbs but at least you won't have too worry about it ruining your lines.:D
  8. D-Russ
    D-Russ
    oj and Speed Gems like this.
  9. cs39ford
    cs39ford
    image.jpg My red fuel lines on my 39 ford
  10. Cymro
    Cymro
    The clear red lines look the part, but as KFC mentioned in his post, the tubes softening and the petrol turning red (gasoline slowly dissolving the tubes), I would think twice about using them having experienced an electrical fire in my own car many moons ago, and ***isting with the rebuild of a friend's gl*** bodied (OT) hillclimb race car that was virtually burnt out due to a ruptured fuel line, L will only use flexible petrol pipe that is designed for today's petrol (and Ethanol, plus other additives). Hard lines properly fitted and Aeroquipe style (Earl's in the US?) stainless braided pipes are also safe.
    Take care guys it's not worth the risk of cremating your ride, possible injuries to occupants just for the sake of looking good!
    afaulk likes this.
  11. oj
    oj
    3/8ths stainless tig welded
    D-Russ likes this.
  12. Daamn.. My phone seems to like that image... Sorry 'bout the repeats...
  13. jimmy1931
    jimmy1931
    Split old school blower setup.
  14. Just Gary
    Just Gary
    Stainless fuel, vacuume & PCV lines:
    D-Russ likes this.
