Projects Show your Floorless project - before & after pics
Discussion in 'The Hokey Ass Message Board' started by mercjoe, Nov 29, 2008.
  1. mercjoe
    mercjoe
    Hey guys
    Would like to see your project's floors as it were by the time you got it.
    "NO floors" at all kind of project would help some more. Some after pics would be appreciated also.
    My 34' floors are SO gone im afraid its gonna be easier to get a 2nd car.
    Gonna have to cage it to avoid the swinging when trying to move it :eek: Scary
    Gonna post some pics tomorrow.
    Thanks
    Diego
  2. Evel
    Evel
    Che...
    I don't have any before pix but I really had no floors to begin with..
    heres some pix as we built them tho..
  3. biscuit eater
    biscuit eater
    Holy **** that's some nice looking work, I wish you lived around here.
  4. hot-rod 33
    hot-rod 33
    what size tubing and what gauge metal did you use i need to do my 33 plymouth looks close to your's great stuff thank you john thank you
  5. mratt
    mratt
    It's floor-less.
  6. Evel
    Evel
    It's 3/4 square with 16 gauge sheet metal...
    I can't take all the credit... I did allot but Littleman got it started.. He did one side and I
    copied the other side..
    Then Dave Martinez and I laid the sheet metal..it was a *****... Lots of welding but ya
    its pretty strong :D
  7. Evel
    Evel
    Heres some shots I just found with all the welds finished
  8. James Boys
    James Boys
    from London ONT
    Evel,
    I like the idea of the rear fire wall to seperate the drivers compartment from the trunk and gas tank. I'll be doing the same on my Model A.
    It looks like the floor in the trunk would just be flat and tie into that steel firewall?? How'd you mount the gas tank??
    I'm having the same issues on my 31, trying to mount the gas tank and battery and still keep a useable trunk.
    Thanks
  9. Evel
    Evel
    Ya my plan was to have the inside as sealed as possible... I have a stock T tank that I
    got from Hot rod company and I mounted it between the rails just behind the rear firewall..
    as for trunk space there rally is not that much... but I have a ton of leg room (6'2 I need it )
    Heres what it looked like before I made the trunk area..
    The Battery tray just clears the spring and we made mounts that come off the
    frame...its really a tight fit all around...
    Heres what it looked like just before upholstery
    Finished
  10. Slag Kustom
    Slag Kustom
    31 a pick up
    50 ford coupe
  11. mercjoe
    mercjoe
    Che, what an awesome work.
    Could you explain the process ?
  12. mercjoe
    mercjoe
    Another great job. Men, how do you do that, I wouldnt even know where to start from :mad:
  13. Evel
    Evel
    Cut, Fit, Grind, Weld... Repeat 100000000000 times :D
    really tho..
    get the body where it spose to be make sure its a perfect clamp it down..
    if you look in the first 2 pictures you can see what we started out with... laying the the
    square tubing on the frame and working off of that.. it's kinda hard to explain... you just
    build a grid or I like to call it the rib cage :D I think we did a bit of overkill but when you got
    littleman on your team he's going to make sure I can go 300 MPH and the floor still
    will be in tact... hahahahah but ya its kind of a puzzle of sorts.....
    if you got questions how we did what...I might be able to answer them better...
  14. ...doc...
    ...doc...
    from Houston
    damn, I am going out to hit my car with a hammer now.
    **** that is some NICE work
  15. Ken Carvalho
    Ken Carvalho
    Beautiful!!!, EVEL... and "bear with me here"!!! I am ---NOT--- being sarcastic: In your deck lid it looks like the diamond tuck is BEHIND the holes, am I seeing that right? and my next question is what are the blue highlights around those holes??? Custom paint, graphics, "chalk" to line out stuff??? Maybe that is a paint scheme I am not seeing on the whole car?? Like I said NOT being an *** or SARCASTIC, I am just wondering!!!
    P.S. the MFS on the plate, You got VERY lucky, or is it a custom made plate??? It ALL looks good man...Ken
  16. Evel
    Evel
    hahahahaha you crack me up...
    Yes those are fades around the holes with Diamond pleat instert behind them Donnie from
    imperial Customs (Painter) did that as a suprise cause he knew how much I love fades...
    LIVE WIRE has a dark blue fade that runs along the bottom of the body and up on the
    the inside of the wheel well and around the bottom of the rear.. also on the bottom of the
    grille shell.. you will be able to see all the detail in the next issue of Rod and Custom..
    the whole drive line is also painted dark blue with light blue fades...
  17. axeman39
    axeman39
    from Saco Maine
    [​IMG]Here's my 39 Pontiac, I had to remove the factory X frame and build my own
    [​IMG]Then I started on the flor grid
    [​IMG]Then I built the shifter boot mount
    [​IMG]Then the ****** hump
    [​IMG]A few bead rolls for strength
  18. Ken Carvalho
    Ken Carvalho
    Cool, sometimes when I ask people questions, they get all Bent & pissed (don't wanna piss YOU off as then my MFS discs would all be covered in pee when you ship them to me!! HAHAHA)!!!
    Cool on Donnie!! I have talked to him and know him from the Boulevardos page, VERY nice & TALENTED guy. Didn't realize "live wire" was yours (doh!!! I'm sorry!!) very nice man VERY nice....Ken
  19. axeman39
    axeman39
    from Saco Maine
    [​IMG]Sorry I didnt get any pics of the toe boards going in
  20. Evel
    Evel
    No worries... I like to answer questions :D
    Oh ya and speaking of Donnie he found me that plate on ebay like 4 years ago...
    and you can get the would LIVE WIRE build on DVD sooon (Shamless Promotion) :D
  21. axeman39
    axeman39
    from Saco Maine
    [​IMG]Now for the rears
    [​IMG]That's where I'm at now.
  22. Evel
    Evel
    Nice Axeman... you got some time in that for sure..
  23. Ken Carvalho
    Ken Carvalho
    Damn EVEL, I had not F'in idea that was being built!!! (yeah I am slow!!) ****IN" beatifull, WOW!!
  24. Evel
    Evel
    hhahaaa ya I've only been posting about it for the past 2 years.... :D hehehehe
    Thanks man..
  25. deadendcruiser
    deadendcruiser
    1956 Buick
    Before...
    After...
  26. doliak
    doliak
    Here's my dads floors in his 33 plymouth that i fabricated for him from 16 guage cold rolled steel. the car sits on duece rails with a custom rear kickup so the floors were done a touch different than stock. I will put some beads in em for strength but i dont use the tubing underneath, nothing wrong with it just wanted to show another way.
  27. mercjoe
    mercjoe
    Hey Evel,
    Only place my Tudor's body could rest is on the ground right now ;)
    So.., I guess the tubing (cage) rests over the frame (already welded to the frame?) and then the body is mounted on the cage and welded together once you reached your desired stance (weld cage to pillars ?!?!).
    In few words, the cage is the actual new floor, then skin is added to it.
    Is this cage approach because of the channeling or to bring more strenght to the body or what ? whats the big difference between this and standard new floors.
    Thanks a lot
    Diego
  28. Bad Luck Engineering
    I couldn't find any before pics of the floor but here are of few of my finished project.
    Maybe not as smooth looking or weather resistant as the convetional sheet metal route but it sure made for a fun ride.
    I Used 1" box tubing for the subfloor and 1/2" expanded metal sheet for the floorpan. I welded threaded bungs to the subfloor and bolted through the sheet so that I would be able to remove it later for easy access.
  29. chaddilac
    chaddilac
    is that a rat rod?
  30. Circus Bear
    Circus Bear
    Love the cross ram, but I have to ask why a duece frame was used. Mopar frames and suspension are RAD. Plus they have they have those kick *** W axles.
