shrinking hammer
Discussion in 'The Hokey Ass Message Board' started by sfckiddo, Jan 27, 2013.
  1. sfckiddo
    sfckiddo
    dolly on or dolly off?
  2. Chaz
    Chaz
    As I understand it... Dolly on. But the shrinkage is almost unnoticeable. Let me know if you have better luck.
  3. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Not that it matters, but are you talking about the '' spiral '' faced hammer or the '' meat tenderizer '' faced hammer? Both would be used '' dolly on '' ,but neither are a great way to shrink a stretched area on a panel! These type of hammers leave the panel somewhat '' gashed & scratched '', and thats never a good thing!
    The ******* type files work well for some types of stretched metal, but a torch, hammer & dolly or shrinking disc would be my choice over a '' shrinking hammer "
    " Do not reach greedily for the Kool-Aid "
  4. Weedburner 40
    Weedburner 40
    I have never had much luck with the shrinking hammers, but I love the shrinking disc for minor work then the old torch, hammer/dolly, wet rag for larger areas.
  5. saltflats
    saltflats
    from Missouri
    Guess I need schoooling on the shringing disc. What is it and how do you use it?
  6. LowerthanLife
    LowerthanLife
    theres a few youtube videos, you'll find them, just search for shrinking disc and they'll come up.
  7. Chaz
    Chaz
    The shrinking disc works...
  8. tedley
    tedley
    from canada
    40 yrs and never really found a use for a shrinking hammer. LOL it actually stretches the metal with those little square dents and now you have more to do. Junk in my opinion. Run a grinder over it and make a regular hammer.
  9. pimpin paint
    pimpin paint
    from so cal
    I use mine as a door prop when I can't find a block of wood:D
    " Spending a nation into generational debt is not an act of comp***ion "
  10. budd
    budd
    i watched a friend one time do a little shrinking with just a regular body hammer and dolly, he kind of swiped the metal, a glancing blow, it was a small area but it did the trick.
  11. gimpyshotrods
    gimpyshotrods
    Shrinking disc. Get one. Dent up a piece of s****, and practice.
  12. hotrodbuilder32
    hotrodbuilder32
    they do work but only in verry special cir***stances, and you should use a block of wood behind it instead of a steel dolly, hockey pucks and tubber dollys workwell too
