Technical Side Mount Motor Mount Hack SBC (tech week)
Discussion in 'The Hokey Ass Message Board' started by Lcats, Oct 5, 2015.
  1. Lcats
    Lcats
    So after searching for taller mounts for My 49 Chevy AD ---and not finding anything and my shop is not full of metal stock and equipment to cut, stamp and pound. I found some unused suspension energy lower control arm bushing from my G-body build- cut them with a sawzall (I needed a 3/4" more lift). The truck had CE cushions which sat too low and the Fuel pump was hitting the crossmember. Results...below. Hopefully they will work out. The base ring is from rear diff upper arms. ImageUploadedByH.A.M.B.1444089632.960442.jpg
  2. 54fierro
    54fierro
    from san diego
    Good idea. I imagine you can find a lot of uses for those bushings elsewhere also.
    Nice tip.
    Lcats likes this.
  3. I did something similar in my 54 Chevy, worked well.
    Lcats likes this.
