Sidedraft Carbs, there has to be someone other than Inglese.
Discussion in 'The Hokey Ass Message Board' started by El Caballo, Sep 29, 2003.
  1. El Caballo
    El Caballo
    from Houston TX
    Part No. System Description Price
    IA1200H Twin DCOE. (2) 40mm Carbs. w/stacks (Air cleaners optional) $1,050.00
    Whoooo-weee! Those boys at Inglese are PROUD of their stuff!
    Wayyy too deep for my pockets. Who else sells 40mm DCOE carbs? This sounds like a job for Dr.J, I'll bet he knows. Anyone?
  2. metalshapes
    metalshapes
    I have 2 pics on the " Webers on S/blocks" thread.
    I could sell you the carbs off that, or if you are running a SBF, the whole thing.
    P/M me.
  3. El Caballo
    El Caballo
    from Houston TX
    sent you one...
    bttt
  4. BigJim394
    BigJim394
    If you want to fab your own manifold you could use some of the big sidedrafts that the Harley guys used to use in the 70s: Mikuni, SU, Dellorto, maybe Solex....my memory is failing me....I know there are others.
    There used to be ads in all the Custom Bike/Chopper mags for different sidedraft set ups for the big twin. Some of the small airplane engines of the 50's and 60's used sidedraft carbs too.
  5. Look at the Datsun 240Zs in your local yard. I spied some of them a while back. A copy of a DelOrto I think?
  6. trey
    trey
    look around for used volkswagen stuff. they use dells and webers that would work good, if you want to do a custom setup.
    trey
  7. metalshapes
    metalshapes
    El Caballo, I send you a reply.
  8. lakes modified
    lakes modified
    There are marine applications that use side drafts like the ones used on the 54 vett. and later AMC nash & etc.they were carters if i remember correctly.
  9. El Caballo
    El Caballo
    from Houston TX
    I'm looking for something that will work on the inglese 4bbl carb adapter that they sell. Hell, if someone else has a cheaper one, I want to know about it!
  10. volken65
    volken65
  11. bigron
    bigron
    you can go to a harley swapmeet and get a couple of s&s carbs for $150.00 ea. they are about $300 ea new.
  12. Ayers Garage
    Ayers Garage
  13. Deuce Rails
    Deuce Rails
    Inglese is extremely expensive.
    Webers in general are kinda expensive. Cheaper alternatives are Weber clones: the Mikuni/Solex PHH and the Dell'orto DHLA. All a pretty similar sidedrafts. (Although I don't have any real experience with them.)
    As a last resort, check eBay.
  14. haring
    haring
    There is a guy on eBay that has been selling Weber, Dellorto and Solex carbs for a few years now. I have not purchased anything from him, but I talked via email and he was helpful with questions. His prices are CHEAP compared to anyone else, probably because he's in Italy those carbs are common there. Check it out: Alfa1750 's auction page
    For example, one Weber DCOM sells for $90, a Dellorto is $65, and a Solex is $45. He also sells rebuild kits. With an eBay rating of 946 (and only one negative), he seems like a safe bet.
    I am thinking of building a 3x2 side-draft Ford 300 engine, and will probably buy from this guy. Let us know what you do.
  15. Kinky6
    Kinky6
    I bought three of the Dell'orto's from that Alfa guy, reasonably fast service from Italy. He advertises rebuild kits for them, as well.
    If I have to, I'll build a 3x2 intake for my Ford 200 6 cyl; but I still would like to buy a Lynx #190 intake from Australia to mount them on.
    Later,******6.
  16. fordiac
    fordiac
    from Medina, Oh
    lots of british cars used side draft carbs.
    lots of MGs and whatnot used twin sidedrafts, triumphs did too.
    I would guess that you would want to use a set from a larger engine like what is found in a Triumph TR6, MGC, or any of the big Healys(if they had them)
    carbs on ebay
    two sets of these, would look cool next to each other.
  17. metalshapes
    metalshapes
    Those British SU Carbs are not in the same league as Webers and Dellorto's IMO.
    And they would be a real****** to Syncho.
  18. fordiac
    fordiac
    from Medina, Oh
    i was just throwing out ideas.
