Technical Signal Stat 900 Clamp
Discussion in 'The Hokey Ass Message Board' started by harleycontracter, Mar 27, 2014.
  1. harleycontracter
    harleycontracter
    Can you buy a replacement clamp for this signal switch or just adapt a band clamp with small screws and a couple of small metal plates ?
  2. Hotrodmyk
    Hotrodmyk
    You need the two "U" shaped brackets that attach at the threaded holes pictured. Then you can use a regular hose clamp.
  3. tb33anda3rd
    tb33anda3rd
    i will look in the parts room tomorrow, i might have the pieces.
  4. harleycontracter
    harleycontracter
    Great ! Thank you. I still want to get down to meet you 33. Just been crazy lately
  5. tb33anda3rd
    tb33anda3rd
    checked my turn signal pile, i do not have an extra clamp, i actually am missing a couple that i probably robbed from. here is a couple pictures of what it looks like;
  6. harleycontracter
    harleycontracter
    Got it Thank you... Now for the hunt. Anyone out there ????? I'll be in touch thanks again
  7. harleycontracter
    harleycontracter
    Anyone know if somewhere makes repops?
  8. 39 Ford
    39 Ford
    I found a guy that had clamps on e-bay last year worth a look.
  9. harleycontracter
    harleycontracter
    Ok I'll check
    Thanks
  10. fulltimeforester
    fulltimeforester
    from california
    I just have to write this, take it for what it's worth.
    Two wrongs don't make a right, but three rights make a left.
    It's easy to make a right turn, not so easy to make a left turn (traffic)
  11. harleycontracter
    harleycontracter
  12. harleycontracter
    harleycontracter
  13. they don't look to hard to fabricate
  14. I had the same problem with one i got at a swap meet, and just made one out of a piece of flat copper with a couple of holes in it. The copper is soft and moulds around the column nicely.
