Technical Silly Carb Question
Discussion in 'The Hokey Ass Message Board' started by greaseSlinger57, Jan 21, 2020.
  1. greaseSlinger57
    greaseSlinger57
    I got myself a double pumper carb from my buddy for free and I got a rebuild kit but it didn't include seals for this tube. I don't know what the tube is called or where to find the seals! Could someone help me find them?
  2. jimmy six
    jimmy six
    Get an o-ring kit from Harbor Freight.
    Double pumpers I've had and seen did not use a single feed from the front bowl and tube. I'd get new double feed bowls and eliminate the tube. Summit, Jegs, Speedway, Compe***ion Products, etc.
    greaseSlinger57 likes this.
  3. oldiron 440
    oldiron 440
    There just O ring's I believe. It's been a long long time since a double pumper had a single inlet.
  4. brigrat
    brigrat
    from Wa.St.
    What's the "list" number on that carb?
  5. deadbeat
    deadbeat
    Any speed shop will carry those O rings. They fit on the ends of the transfer tube. Be careful when ***embling your carb back together as sometimes they get "pinched" and will leak, I use a bit of rubber grease, cheers
  6. Mike VV
    Mike VV
    from SoCal
    I believe it's a big and little...Quadrajet style Holley.
    The correct kit should have the o-rings included.
    Mike
  7. UNCLECHET
    UNCLECHET
    It's called the "transfer tube". Old carbs use O-rings. New carbs use a little hat shaped seal. Go to your local speed shop. Use a little grease on the seals when you're ***embling the carb. It'll make it easier and protect the seal.
  8. greaseSlinger57
    greaseSlinger57
    I’ll check it out when I get home from work!
  9. greaseSlinger57
    greaseSlinger57
    Thanks everyone for helping out. So much good knowledge on here even for the silliest of quarrels
