Technical Silly question
Discussion in 'The Hokey Ass Message Board' started by JDart270, Jul 4, 2016.
  1. JDart270
    JDart270
    So i got a 1950 dodge meadowbrook with the flathead 6 not to long ago. Its almost to the point of running it for good periods of time, my question is does these motors require leaded gas? Pic for attetion[​IMG]
  2. aaggie
    aaggie
    I don't know if it would require leaded gasoline but that was all that was available when it was new. Since it is probably around 8:1 compression I would think detonation would not be a problem with 87 Octane gas. The only other concern would be the valve seats and at the performance level of the engine I wouldn't worry about it.
    If the engine has a lot of miles it might be a good idea to pull the head and clean out any Carbon build up. Take a compression test and see if it is fairly equal in all six cylinders.
    JDart270 likes this.
  3. squirrel
    They don't require leaded gas. You'll be ok.
    JDart270 and 1927graham like this.
  4. JDart270
    JDart270
    Thanks for the quick replys guys!
  5. elba
    elba
    No ! I have one of those engines and it likes the cheap gas .
  6. bchctybob
    bchctybob
    If you start driving it a lot and especially if you lug it around, it won't hurt to put a lead additive in it every other tank or so.
