Technical SILLY QUESTION
Discussion in 'The Hokey Ass Message Board' started by verde742, Oct 13, 2015.
  1. D.Conrad
    D.Conrad
    Try the gauge and sending unit before you install.
  2. DDDenny
    Funny story, but partially OT(or completetly, depending on your OT tolerance).
    I worked with an old guy years ago, his biggest contribution around the break table
    seemed to focus on the gas mileage he got with his car, good mileage or bad, that seemed to be all he could talk about, so one day a couple of guys got a little tired of the same old story and decided to F@#$k with him.
    Once every few days; these guys would take turns adding a little gas to his gas tank after he came into the building in the morning. He would start his routine with how he just couldn't understand how out of the blue his car started getting "really great" gas mileage.
    Week after week this went on(with crazy exagerations) about not having to put gas in his car for weeks.
    After a while we just couldn't stand it any more and finally broke the news to him.
    He never sat at our break table again.
  3. Its just too bad there isn't some sort of a phone ap for fuel gauges, some sort of a GPS thingy. :D :D :D
    lothiandon1940 likes this.
  4. stimpy
    stimpy
    the phone app is built into the dashboard .. :rolleyes:
  5. 49ratfink
    49ratfink
    that was an episode of Gomer Pyle USMC. if I remember right they were doing it to Sargent Carter and he had a 60 Dodge that got crushed by something falling off a crane in the end.
  6. DDDenny
    Gaaaaawly
    I'll have to take your word on that.
    Model T1 likes this.
  7. belair
    belair
    Nope. It always works perfect until you install it. One of the fundamental principles of the universe.
    Model T1 and kiwijeff like this.
  8. Jalopy Joker
    Jalopy Joker
    go old school and mount gas tank inside cowl and use a sight gauge
  9. Or go totally high tech and mount a sight gl*** on it behind you and a go pro.
  10. stimpy
    stimpy
    then you get to watch it after the trip ....
  11. Yes real time and after the fact. Shazaaaaam.
    Or you could duct tape your smart phone back there and periscope it. :D
  12. stimpy
    stimpy
    my smart phone
    cant say its not traditional ......
  13. lonejacklarry
    lonejacklarry
    We did that to a guy with a German diesel import in the late 70's. He was up to about 100 mpg and was telling everyone about his good fortune, especially his friends at the dealership. Most thought he was crazy.
    After the new wore off with us, we began siphoning diesel fuel out of his car. He could not figure out how he could gradually go from 100 mpg to about 12 mpg. He blamed it on bad fuel.
    We never told him!
  14. David Gersic
    David Gersic
    from DeKalb, IL
    Whoever did the tank install in my 37 did that, but the access hole was cut 1/2" off center, so you could see the top of the sender, but you couldn't actually remove it.
    I fixed that.
  15. seb fontana
    seb fontana
    from ct
  16. Model T1
    Model T1
    I tried to come up with a silly answer for your silly question. But this gas gauge **** is serious! On my 1955 Chevy wagon I've tinkered and replaced two or three sending units and gauges. Still shows 1/4 tank when empty.
    I've bent the float wire every which way and it still shows 1/4 tank even at empty. You have to move the rear end to lower the tank.
    So it's been showing 1/4 tank after I use 3/4 for years. I just fill it and guess by looking at the odometer.
    My Model T on the other hand was always right with the sender. Or does a stick poked in the tank count?
  17. blazedogs
    blazedogs
    Ohms resistance is wrong between fuel sender and the gauge..
  18. squirrel
    In a situation like this, I'd test the gauge by connecting the sender wire to ground. If it shows 1/4 tank, then the gauge itself is reading wrong. You might be able to bend the needle to get it where it belongs, or else find a good used gauge to replace it (lots of guys get rid of the stock gauges, they're not hard to find).
    If the gauge is not the problem, then it might just have too much resistance in the wiring between the sender and the gauge. Make sure the sender is grounded, and make sure there are no bad connections along the wiring path.
  19. falcongeorge
    falcongeorge
    from BC
    whats a phone app?
  20. DDDenny
    What's a GPS thingy.
    lothiandon1940 and falcongeorge like this.
  21. 1946caddy
    1946caddy
    from washington
    Winnamucca would be my choice as were to be stuck for a few hours
  22. Its the reason that people like us have to just fix the damned gauge or carry a can of gas. We don't know what one is, don't want to know, and even if we did that wouldn't work either. :eek: :D
    Model T1 and falcongeorge like this.
