Technical Simca angle distributor adapter 59AB
Discussion in 'Traditional Hot Rods' started by 3w Hank, May 11, 2023.
  1. 3w Hank
    3w Hank
    Today I got a angle adapter to look at ( as I can bought )
    It's Simca made ( France ) but it has a Ford logo on it.
    Not a clue on years, but maybe this engines was in military or industrial maybe at 60's or the 70's ?
    It might fit for my aplication but the magnet will be maybe up to 1" higher up than a 8BA cam cover, and it might look odd.
    Was this something USA hot rodders used, or was this something from 'another part of the world and later on' and that never came to USA hot rodders ?
    CC from cam cover to center is 3" so its between the short and long normal angle adapters I has seen.
    Ned Ludd and Bill McGuire like this.
  2. 62rebel
    62rebel
    My guess is that it's either French Army use or possibly industrial application. They probably didn't want to deal with the crab distributor any more than they had to.
  3. Neat discovery, following to learn more.
  4. Pete1
    Pete1
    from Wa.
    That was for a Simca V8 which was a later Europeon version of the Ford V860.
    You can adapt just about any modern ignition to the drive including various magnetos but angle drives never work as well as direct drives.
    Other parts of the engine can be adapted to the 60 for racing. We used to make stroker cranks for the 60 out of Simca cranks. We couild get 166 ci with stroke and bore. That is the cl*** limit.
    vtx1800, RaceFink and Outback like this.
  5. Atwater Mike
    Atwater Mike
    Yep. ^^^^ The Simca model was 'Vedette'.
  6. 3w Hank
    3w Hank
  7. Pete1
    Pete1
    from Wa.
    Ford V860. Optional engine 1937 to 1940.
    V8-m likes this.
  8. 3w Hank
    3w Hank
    I did read Ford/Vedette on Wiki, 49-54.
    In a picture I found it showed camcover as the 8BA.
  9. Hopefully it comes with the drive shaft and the TWO gears that are needed to make it work. You may want to find the distributor that goes with it - just for the lower drive gear. You could probably shorten it to bring a magneto further down, but hard to tell how it might fit unless one mocks up an engine with a fan belt and generator up top.
  10. 3w Hank
    3w Hank
    I has the gears, axles ( look decent )
    Pete1,
    Well a direct drive ( 8BA ) will be better than a extern drive but in reality both has angle gears and it rotates - so in reality how much less ’good’ is the angle adapter design the pratical way see a ’issue’ from the 8BA.
    This Simca unit, hmm, should actually work on my aplication and its made by Ford, ( but )
    vtx1800 and Outback like this.
  11. V8-m
    V8-m
    from Alaska
    I have the same one for my 81A and will run with magneto. There is one problem with this stetup. Magneto is almost touching v-belt. It's very close.
    I also have original distributor which is made by Scintilla.
    Asphalt Demon likes this.
  12. 3w Hank
    3w Hank
    Thanks for the pictures.
    How is timing, does go steady ? ( as some said its not accurate )
  13. V8-m
    V8-m
    from Alaska
    Do you mean magneto? If so it's not adjusted yet. Weights are located in the base of the magneto and you can change/ adjust them. A little bit complicated and time consuming.
    Original dizzy photos for reference:
  14. 3w Hank
    3w Hank
    I’mean gears etc on the angle adaptor from the straight 8BA design.
    As some said it was not as accurate.
    Outback likes this.
  15. Outback
    Outback
    from NE Vic, Oz
    Could be due to backlash in the gears? If it's set up with that mind it shouldn't have a problem. I don't have direct experience though
  16. V8-m
    V8-m
    from Alaska
    It depends on gears condition and it`s not adjustable. You need a little bit clearence anyway..it can`t be to tight.
    Outback likes this.
  17. Outback
    Outback
    from NE Vic, Oz
    I imagine the inconsistentcy would be on/off the throttle. But it would work fine
    V8-m likes this.
  18. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I use an angle drive on my crossflow six with two bevel drive gears (Boston HLK101-Y). It seems to work OK up to 7000 RPM. I know two bevel gears compared to a scroll gear drive is not an apples / apples comparison, but aside from an additional point of backlash I do not think driving a right angle flathead distributor would be an issue.
    V8-m and theHIGHLANDER like this.
  19. 3w Hank
    3w Hank
    Yes, I guess in drag mode in gear its no issues but all engines has gears, chain, belt.
    The 8BA has also a gear deal from cam to distributor.
  20. ronnieroadster
    ronnieroadster
    Dale to use this drive its actually easy first the drive to the cam is typical early Ford just an off center tang that locates into the cam slot. The distributer drive is exactly the same way the shaft is simply offset so no additional gear is needed.
    This right angle drive is actually really neat especially considering the Ford script. I have one fir a distributer I simply modified a two piece cap Mallory distributer cut down from a Chevy.
    Ronnieroadster
  21. CheatersPete
    CheatersPete
    If anyone interrested, I have a complete set for sale + one angle adapter
