Simple Green
Discussion in 'The Hokey Ass Message Board' started by flatford39, Aug 23, 2011.
  1. flatford39
    flatford39
    Where is the best place to buy the super degreaser concentrate of Simple Green. I want to use it in my pressure washer to clean the grease of my 28 AA frame.
  2. 59ab
    59ab
  3. stuart in mn
    stuart in mn
  4. chrisntx
    chrisntx
    from Texas .
    I remember the first time I saw the stuff, the demonstrator was drinking it to show that it is environmentally friendly!
  5. Kensey
    Kensey
    from Pittsburgh
    Hey, I don't know if you have Dollar Stores, or Dollar Tree stores BUT they sell this stuff called Awesome. It's orange, in a frosted white bottle with red type. Anyway, it's every bit as good as simple green if not BETTER! And it's a buck. Check it out. It is literally Awesome.
  6. 325w
    325w
    In the factorty they replaced silicon with simple green for lubing the door gl*** rubbers for installing. O'rilleys has it as well as costo.
  7. Hot Rod Chris
    Hot Rod Chris
    That stuff is AWESOME... No literally... Its called awesome.... just kiddin, that stuff really good and cheap too
  8. hotrodladycrusr
    hotrodladycrusr
    I buy it by the gallon at Home Depot.
  9. oldolds
    oldolds
    Castrol Purple Power. Seems like the same stuff. Walmart, Advance Auto, Auto Zone.
    That is here in PA. They also sell it in 2.5 and 5 gallon size. I mix it up 50/50 with water and throw old cast iron things in it that I sell in an antique shop. Old frying pans, apple peelers ect. Let stuff soak about a week it is bare clean metal. Watch your hands with full strength, it is pretty caustic. Also use in well ventilated area when full stength.I have used all the above products with the same results.
  10. flatford39
    flatford39
    Thanks everyone. This computer is making me lazy...
  11. mj40's
    mj40's
    x2 for the Awesome cleaner.
  12. Bleach
    Bleach
    Are you sure it was SG? The spray alone from that **** makes me gag. It's a good cleaner otherwise.
  13. Big Bad Dad
    Big Bad Dad
    X2 That stuff is "Awsome", and only costs a buck. Starting to love our new local Dollar General. Oil, brake fluid, cleaning chemicals, etc. is cheap there too. :D
  14. BISHOP
    BISHOP
    That stuff is the best. No joke, I havent found anything better. Makes simple green look stupid.
    Its actually 2 bucks, and more yellow than orange.
  15. choptup 49
    choptup 49
    from so-cal
    I use awesome for everything! From white interior to whitewalls! Even the shower! LOL
  16. Saxon
    Saxon
    from MN
    I thought for degreasing the dollar store oven cleaner was the best. Simple green is a great product for cleaning my ww.
  17. This stuff is very good, just don't spray it on your paint...
    -Dean
  18. Leevon
    Leevon
    from Nixa, MO
    I use diluted simple green for dang near everything. I keep a chemical sprayer full for washing cars, parts, the garage floor, whatever. Works real good as a pre-wash for bugs on the front of cars. Then I keep a more conentrated spray bottle for other stuff. I have used it to install windshields with success.
    Two things I've found: The "green" stuff from the dollar store ain't the same. Purple Power will eat your skin off (literally), you should have seen my Dad's fingertips.
  19. r8odecay
    r8odecay
    Yep, and you won't feel it burning you until it is too late.
  20. mustang6147
    mustang6147
    from Kent, Ohio
    The best cleaner out is Formula 50 by Zep. The rest is garbage. F50 is very inexpensive too, and is bought in concentrate so 5 gallons can make 15 or 20 gallons.
  21. scootermcrad
    scootermcrad
    Two words of caution about Simple Green...
    Once I was putting together a new Triumph clutch and the manufacturer suggest soaking the fiber plates in Simple Green before installing. (can't remember why) Unfortunately the next morning when I went to pull them out of the container they were soaking in, there was nothing left but the plates the fiber was bonded to. They replaced the clutch at least. HAHA! So it DOES have some toxicity.
    Second word, and maybe a no-brainer, don't clean aluminum parts with it that are intended to be welded. It will contaminate the weld.
    Other than that, great stuff! We keep spray bottle of it around and buy the gallon jugs of it on a regular basis.
