Simple Hemi question???
Discussion in 'The Hokey Ass Message Board' started by uglyoldcrow, Mar 17, 2013.
  1. uglyoldcrow
    uglyoldcrow
    Well this is my first (and last ) Hemi project. I'm putting a 241 Red Ram Hemi in my 1934 Plymouth PF Coupe. In my hopes of the motor fitting between the fenders and hood, I had to notch the inner fenders and fenders about an inch on both sides. Before that I looked to see if the valve covers which were hitting could be modified a bit to clear the fenders. I removed the Plugs,tubes valve covers etc. to see if there was any room to trim the covers. No can do! This was the first time I ever touched a Hemi motor. Here's my question?
    In putting everything back together is there any tool or trick to getting the wire caps back on the spark plugs? I'm sure I can make a tool but was wondering how you hemi guys do it. ?
    I got the front clip fitted so all is good! Jim
  2. AndersF
    AndersF
    The easy way is to use a sparkplug wire kit thats are made for Hemi.
    They have long insulator so you can reach the sparkplugs.
    But i have used a long slim plier put them on the sparkplugs when i didnt have correct wires for my Hemi.
  3. RichFox
    RichFox
    Yes you need the insulator tubes. I have made some from Phnolic. Which I don't know how to spell. Delrin would also probably work
  4. manyolcars
    manyolcars
    How do you keep the spark plug tubes from leaking on the early hemi? I dont use the cover that goes over the spark plug tubes
  5. George
    George
    You can try some RTV, or something simular around the seals.
  6. RichFox
    RichFox
    I made some spacers that pressed on to the tubes and fit between the tube flange and the rubber grommet when the plug was tightened. I didn't use sealer. But this was on a race car.
  7. TR Waters
    TR Waters
    from Vermont
    Use the under tube washer set that I sell. And make sure you have the correct length tubes.
