Simple question!
Discussion in 'The Hokey Ass Message Board' started by Greaser Bob, Feb 1, 2009.
  1. Greaser Bob
    Greaser Bob
    Got an early 70's sbc recently for a rebuild. Bought a th350 ****** to mate, but see the torque converter has 3 bolt flanges on it and the flex-plate has 6. Measured the distance between the 3 bolt holes and is in no way going to work! Around 9 3/8" or so.
    Man I'm used to much older motors so tell me, since the flex plate is the cheaper of the two, where do I look for one to use?
    Bare with me if this is an ignorant question please.:rolleyes:
  2. az/willis
    az/willis
    napa,ect. has em,the 6 hole one may have two differant bolt patterns.I am surprised it dosent fit the converter
  3. Jimv
    Jimv
    Should bolt up, rotate it & see if they align.I think all flywheels are 6 bolt for this reason.
    jimV
  4. propwash
    propwash
    from Las Vegas
    Jimv is correct - it will bolt up and the bolt distances are purposeful - balance and all that rot.
    dj
  5. pasadenahotrod
    pasadenahotrod
    from Texas
    Chevy flexplates all have 6 holes , 3 each on two different size circles, usually 3 are round and 3 are oval.
  6. charleyw
    charleyw
    My 454 uses an externally balanced 6 hole flexplate. The converter has 6 threaded blocks.
  7. hunter_lake
    hunter_lake
    Yeah .... try again, it should fit
  8. 325w
    325w
    Make sure it's mounted the right way. Ask me how I know. After the engine trans was in the car............
  9. 29nash
    29nash
    from colorado
    What they said............Crankshafts have the same bolt pattern, whether autotomatic or standard installation......................
  10. Greaser Bob
    Greaser Bob
    You guys Rock! Went out this morning and sure enough there are 2 different bolt patterns! Thanks very much! Love this board!
