Hot Rods Simple test stand wiring diagram
Discussion in 'The Hokey Ass Message Board' started by ahshoe, Mar 25, 2018.
  1. ahshoe
    ahshoe
    Came up with the simple wiring diagram to test start an engine on a test stand. I want it simple...Just start and run to check engine condition.Am I missing something or should it do the job. Please see my rough design attached.
  2. squirrel
    That could work.
  3. You might find moving the wire from "I" on your solenoid to the coil side of the ballast resistor will help it start easier though.
  4. RMONTY
    RMONTY
    You can also run a wire from the "exit" or "load" side of the starter ****on directly to the coil to byp*** the ballast resistor. What this will do (I think??) is give full "power" to the coil during the time that the engine is being turned over by the starter. The drag the starter motor puts on the battery could reduce the voltage available to the coil for the best spark.
    I had to do this with my old 9N Ford Tractor to insure a quick start, especially when it is cold. As soon as you take your finger off the starter ****on it drops that wire out of the circuit and allows the ballast resistor to do it's job. I probably didn't use all the correct terminology but it worked for me.
    SIDE NOTE: Not trying to hijack the thread but if anyone sees anything wrong with this approach/method please chime in. I would hate to mislead anyone, but as I said, it appears to be working for me.
  5. RMONTY
    RMONTY
    Fan Attic has the same idea as I do it seems.....just a different way to approach it. Not sure mine is the best.....but the principle is the same. He just typed it quicker than me. :)
  6. BJR
    BJR
    Fan Attic caught the only error in your diagram. It byp***es the ballast resistor when cranking the starter for full 12 volts to coil, only when starting. On run power then goes through the ballast resistor to save the points from burning.
    I need to type faster!
    olscrounger likes this.
  7. squirrel
  8. ahshoe
    ahshoe
    Just to confirm...I should REMOVE the wire that I had going to the "I" side of the solenoid and run it directly to the coil side of the ballast resister? Then NO wire is needed from the on of switch to the "I" post of the solenoid.Correct?
  9. RMONTY
    RMONTY
    Run the wire from the I terminal on the solenoid directly to the + terminal on the coil, or run it to the terminal on the ballast resistor "outlet" side. When the solenoid is energized, there should be battery voltage present on the I terminal. I hope that makes sense.
  10. RMONTY
    RMONTY
  11. RMONTY
    RMONTY
    The Ballast Resistor will be in the wire that is marked "From Ignition Switch "Hot" in the Run Position.
  12. ahshoe
    ahshoe
    Like this now?
  13. RMONTY
    RMONTY
    Yes sir that should do it! :cool: Now get to wiring and show us a video of your test stand and the engine running. Coincidentally, I am working on mine today as well.
    wraymen likes this.
  14. BigEd
    BigEd
    Does polarity matter on a test stand if your car is a positive ground system?
  15. RMONTY
    RMONTY
    The test stand doesn't care. Visualize it like it is just a section of the ch***is of the car that the engine is going in, and wire everything accordingly.
  16. tubman
    tubman
    Not for a simple test stand; just hook up the wires properly and go. I can't think of any component on the stand itself that is polarity sensitive. However, a dual voltage/dual polarity test stand like I need, is a whole different ball game.
    The only change I would make on the O/P's second diagram is to have a separate SPDT switch to cut in and eliminate the ballast resistor when running. It can sometimes be helpful.
