Simple things we often overlook
Discussion in 'The Hokey Ass Message Board' started by Malpass, Oct 29, 2010.
  1. Great thread, but this has to be one of the oldest and wisest, MEASURE TWICE and CUT- { drill, ream, hone, bore, final weld, etc., etc... } ONCE. BDM {we are all guilty of that one:D}
  2. Saxman
    Saxman
    During engine ***embly, always check to make sure that you have the correct head gasket, so that you don't fill the cylinders and crankcase of your freshly rebuilt 1934 Chevy engine with coolant, when you only wanted to fill the radiator.
  3. boldventure
    boldventure
    When re-building a master cylinder check the piston you just bought against the one you just took out. I don't know where they looked it up but the parts store sold me one that was about a 1/4" too short.
    Makes sure when you buy a replacement ignition coil they don't give you "the one we give guys when we can't find the one you were supposed to have". The wrong one can be really hard on the points and cap.
  4. BOWTIE BROWN
    BOWTIE BROWN
    i make a list , then forget where i put it .
    **** happens , what i want to know is , when does it stop .
  5. Carpe Noctem
    Carpe Noctem
    from Las Vegas
    when you have calipers on each side that are identical remember to mount em with the bleeders pointed up.
    when building brake hard lines. Triple check which flare you need and leave a bit extra.
    when running a one wire alt remember to install a diode in the signal circuit or it'll keep the car running with the Ign. off.
  6. 56don
    56don
    I used to work in a parts store so always bring in your old part first to match up to the replacement one or otherwise you will just end up coming back to get the right one 50% of the time. Parts stores computers are notorious for being wrong......garbage in,garbage out.Save a trip, bring in the old part first.
  7. Skeezix
    Skeezix
    from NorCal
    "don't be lazy, change your own oil. the *****s at the quickie lube will strip your oil pan threads and put in the wrong oil."
    Also the kids like to use anti seize on the plug....mmm aluminum flakes in the oil no extra charge
  8. Spot_remover
    Spot_remover
    my olds has reverse thread lug nuts too. It took me a lil while to figure this out. LOL
  9. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Making cardboard templates to use when making brackets for alternator .Tried to wing it and hold steel and mark the holes 3 brackets later I got it right with template ....And Dont rush things .......................
  10. Master of None
    Master of None
    Even when you get super excited because your buddy finally got his truck together;and hes running around like a 5 year old at Christmas. Always stop and ask him " Are the rear U-bolts more than one wrench turn tight?"
  11. Mnhotrodbuilder
    Mnhotrodbuilder
    from Afton, MN
    True, however we all had to learn somewhere.
    Jesse
  12. M1Lover
    M1Lover
    As a 17 year old tire "technician" (we called 'em Chimps in MD too!) in 1975, I personally sheered 2 off of somebody's Dart before the manager saw me doin' it and quickly educated me as to what the little L in the center of the stud meant...! Damned Mopars anyway. Never heard a such a thing... H.
  13. Fenders
    Fenders
    Happened to me... and the cause of the low battery was poor ground at the alternator. Ran a direct wire from alternator frame to battery negative, problem solved.
  14. toucan
    toucan
    from sc
    tighten lug nuts!make sure you have gas!
  15. CruZer
    CruZer
    Make sure when you install lights on a car for the first time that the bulbs are the correct voltage. Some aftermarket suppliers still sell lights w/ 6 volt bulbs thinking they will be used in antiques.
    These will work a few times with 12 volts but not for long.....
  16. CruZer
    CruZer
    This happened to me too after helping a friend wire his car and nothing would work.After two hours of useless troubleshooting,we checked the battery output. Yup, dead battery !!!
  17. Mike Miller
    Mike Miller
    I keep forgetting to put the damned rotor back in my distributor.
  18. FWD cars with automatics with 2 dipsticks...don't pull them both out at the same time... ****** fluid does not make a good oil additive... and automatic transmissions don't work well empty
  19. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
  20. Malpass
    Malpass
    I just got slapped with another scenario last night that I should have know better. I've been fighting a no-start issue with my Fairlane, sometimes it will crank right up and sometimes it just flatlines for no reason, i replaced the solenoid, and sometimes i can fiddle with the battery cables and solenoid cables and it will crank up. yesterday after fussing with it for over an hour and a half and leaving it on the battery charger all day and it STILL not showing a full charge, i decided to take a look at the terminals. the positive terminal had some sort of film over it that was keeping the cable from making a good clean contact, two minutes worth of cleaning the terminal and cable, she fired right up no problem.
  21. ragtop50
    ragtop50
    from UK
    I have also done this :(
  22. Antny
    Antny
    from Noo Yawk
    Ask the HAMBers for advice before doing anything for the first time. :)
  23. Mnhotrodbuilder
    Mnhotrodbuilder
    from Afton, MN
    This is great advice!
  24. Bigjake
    Bigjake
    Drum brakes got a big shoe and a little shoe. Just did rears on my brother in laws Dodge and was wondering why the brake drum wasnt wanting to go back on...Had the two big shoes on same drum. Duh.
  25. HEATHEN
    HEATHEN
    from SIDNEY, NY
    One of my friends rebuilt his starter and had just finished reinstalling it when I walked in his garage. He hit the key, only to hear a "click", and I saw a wisp of smoke rise from the battery terminal. I ground the cable back and forth and said, "Now, try it". Guess what? Don't start with the most complicated thing.
  26. ClimisCD
    ClimisCD
    Connected a battery without checking the manual first. Turned out it was a positive ground. Also had an rotation and alignment done on the wife's mini van (yeah thats it) where the guy left the lugnuts finger tight on the p***enger side. That was a nice ride for 30 ft.
  27. atomickustom
    atomickustom
    Get into the habit of laying tools on something OUTSIDE the car (a table, a stool, etc.) instead of putting them all over the engine compartment. Cuts down on the rattling noises as you pull out of your driveway and your sockets, screwdriver, etc. roll off of your motor onto the road.
    I've been working on my own cars for 30 years and only in the past year or two have I started to catch myself laying tools all over the engine compartment and place them on a rolling table instead.
  28. Mnhotrodbuilder
    Mnhotrodbuilder
    from Afton, MN
    Flathead generators need oil.....Who knew :( found this out the hard way last week
  29. BISHOP
    BISHOP
    Tuck your shoe strings in your shoes when riding a motorcycle. I had a shoe string get caught on my foot peg, me and the bike fell flat. I bet it looked crazy.
