Since it's cold, let's discuss the whole, "you can't run an engine w/out exhaust mani
Discussion in 'The Hokey Ass Message Board' started by c-10 simplex, Jan 2, 2010.
  1. If a man speaks in the forest, and there is no woman to hear him...........is he still wrong?
  2. I have an O/T van that was a stalled project, has no pipes on it at all, just manifolds.
    The check engine light comes on after a bit because the one O2 sensor is off and I think it could stand an oil change from running rich, oil smells g***y, but it runs fine, it runs just as nice as my other O/T with the same motor in it. I test drove it that way, drove it to where it is now, and I've started it a couple times when it was 15' or so. Still fine.
    In fact let me ask a dumb question. I pulled a manifold from a third vehicle to put on the first one and there seemed to be no gasket between the manifold and the head. Am I missing something? It came off an ambulance that I don't think has ever been apart.
  3. Frank Jonkman
    Frank Jonkman
    The flaps on some dragsters are to keep rocks and other debris from being kicked up into the headers when towing back on the return road.
    They have no performance enhancing capabilities, just for the rocks.....
  4. plym49
    plym49
    from Earth
    You don't need a gasket between a cast iron exhaust manifold and a cast iron head.
  5. c-10 simplex
    c-10 simplex
    Alright, there's no need to get sarcastic and all. i get the message; i was asking a question because i heard certain things and in the context of cold weather----i've run engines for testing purposes without exhaust manifolds in the summer with no problems.
    The 2 other questions were related to the first, with the main theme being after the engine is warmed up AND (or even before) after you shut it off, would the cold air damage the hot exhaust valve?
    So, the question is basically answered.
  6. c-10 simplex
    c-10 simplex
    Actually, let's continue since i'm picking up more info--- like why dragsters have flaps on the header collectors.
  7. squirrel
    in many cases you don't want a gasket between a cast iron manifold and a head. Gets in the way of cooling the manifold, so the manifold warps more easily
  8. john walker
    john walker
    keeps mice out. you wouldn't want top shower the crowd with rodents, would you?
  9. plym49
    plym49
    from Earth
    What if it was a rat motor?
  10. squirrel
    mouse motor, rat motor, whatever...as long as it's not an elephant
  11. zzford
    zzford
    O-o-o-o...I think I just saw this very same question covered on Mythbusters !!!
  12. cwl52
    cwl52
    like exhaust pipes and manifolds are just for the MAN to make some more money, dude.
  13. fordcragar
    fordcragar
    from Yakima WA.
    Then you should be able to get more of the crowd. :D
  14. corsair
    corsair
    So let me get this straight. The exhaust valve is bending because cold air is somehow getting ****ed into the motor and warping the exhaust valve? Really? And it has nothing to do with the motor running leaner than **** from the open exhaust? Gotcha :rolleyes: Throw some tal*** powder in the air next to your zoomies (which are totally different than an open port.) and see how much powder gets ****ed into the pipe.
  15. What if it's a Hemi.... then they're so you don't shower the crowd with hymens?
  16. Jimv
    Jimv
    some of you "mechanical whizzards" want to shut down this post( which seems to be a legitimate question) & no ones complaining to shut down a 141 reply post about rac**** **** in there attic!!
    i think theres alot of ****ed up priorities on here today!!lol
    jimv
  17. plym49
    plym49
    from Earth
    I would expect that whatever they had --- was what they needed. Taking into account the overall design: rpm, tourque, hp, al***ude, fuel, weight, space, god knows what else.
  18. panic
    panic
    Yes, this is complete nonsense, same as it was the last 35 times someone brought it up.
    H-D and Indian board track racers used ported cylinders: a big slot cut right through the cylinder wall into the bore just above the piston at BDC - the flame just shoots right out.
    Why don't they still do this?
    Only works at full throttle.
  19. hotrod1940
    hotrod1940
    Yes, I was joking. I first heard of the flappers in a cl*** at the 4H club to keep the rain out of your farm tractor engine. This was long before Steven Speilberg and I really found the topic silly and lost my head and said a funny. But I was serious about the B flat part.;)
  20. Road_Rage_Rube
    Road_Rage_Rube
    the whole topic ****s, except:
    you install a big turbocharger
    you set your timing
    you wrench all day
    you have nothing else to do
    you love to waste your time
    you don't got any neighbors
    you read "how to build race engines"
    you always wanted to see a engine break down
  21. Edsel_Presley
    Edsel_Presley
    No idea about the topic, but I heard one that's hard to believe the other day. Supposedly you should never make a mark on an engine with a pencil, because the metal will crack where the mark is made.
  22. Road_Rage_Rube
    Road_Rage_Rube
    I mark all my engines with a pencil, when I change the timing chain/belt......
    strange thing, mine all crack in different spots?????
  23. Say you really wanted to warp the exhaust valves. Really simple and east to do. Retard the dizzy so the timing is really late. drive it like that the exhaust manifolds will get so hot you can almost see through them. Guaranteed to warp valves fry piston tops and get the desired result.:eek: Oldwolf
  24. GMC BUBBA
    GMC BUBBA
    After reading all the answers i am not sure i should even try to answer, but here goes. ( after 40 years of working on cars)
    The logic here is for a engine with a complete exhaust system driving down the road with lets say cast iron manifolds etc. After some time many of these manifolds would crack and break, some even missing huge chuncks of cast iron etc. If the customer ( owner) continued driving in this condition it often would develop a missfire based on a incorrectly seating valve in the cylinder head ( close to the opening). Now as to whether it caused ( the cold air on a stopped engine while hot) the vave to bend, warp or the seat to be come irregular, it really doesnt matter . It did in fact cause a miss fire and the engine had to come apart, to fix the valve on a givin cylinder.
    Seen tons of these over the years on all kinds of engines. Especially on industrial equipment that ran up against the governor and set in the open.
    Myth = No :eek:
  25. meengrinch
    meengrinch
    from ipswich ma
    only thing i can add to this topic is that we ran the flatheads w/o any manifolds or pipes off the motor all the time. not saying it was right but it was done all the time......this was in the 50`s
  26. fab32
    fab32
    Do you live under a rock? There were hundreds of thousands (no, make that millions) of SBC's that left the factory with no exhaust gaskets. The reason that every gasket set comes with them is there were some trucks with gaskets so for about $.02 (about the value of some of your posts) they were included in the gasket set. Ever have any gaskets left over after a rebuild or haven't you ever done one.:(
    Frank
  27. Hambone64
    Hambone64
    Is this ********?
  28. yes just like global warming ********:D
  29. bobss396
    bobss396
    I never use gaskets between the head and exhaust manifolds. After they run a short while, carbon fills in any voids.
    Bob
  30. theHIGHLANDER
    theHIGHLANDER
    In an effort to be a logical and friendly hot rodder, I'm going to guess that early on when racers were experimenting with lighter and lighter valvetrains perhaps some valve of particularly small stem diameter may have seen a slight warpage from full hot shut down at one time or another. As it happens sometimes these scenarios become gospel and an ironclad reason not do 'whatever' creating a 'practice' with additional reasons. Good or bad idea is a moot point. The ******** a**** us has run our engines in limited fashions w/out manifolds or pipes 'just because' but the more seriously ******** a**** us never felt it was a fashion statement for the completed project.
    As far as exhaust waves or pulses is concerned, yes that's quite true that there's pulses and their effects are tunable. What you do with the info you gather is the deal maker/breaker. In 2 strokes (again as many of you may know) it's the sound waves from the exhaust as well as the intakes that are tuned for optimum performance at a given set of pulses or target RPM.
