Since we are so traditional here.
Discussion in 'The Hokey Ass Message Board' started by lippy, Jun 22, 2012.
  1. jfg455
    jfg455
    from NH
    Alky.
    Not sure how traditional it is. I'm sure some of the guys were using it then
    Not sure why someone said gas runs cooler. Alky by nature is colder when it is sparyed. Don't believe me? look at an injection hat or hilborn stack on an alky car and you will see frost on them at times. We have seen a 20-25 degree drop in operating temps on alky as apposed to gas. Besides, it smell good when it is burned!:D
  2. Larry T
    Larry T
    Probably so, when they were match racing.
  3. I think that bean mentioned that the 10 second and faster cars run on methanol (alcohol), now I am making an ***umption that no one is running ethanol which is low grade in the world of alcohol.
    I got a ride in a nine second car, a g***er, when I was in high school, and it ran on gas. That was what the rules stated back then. It didn't make a 9 second p*** with me driving it. But the fella that raced the car took me for a 9 second ride just so I could see what it was like. This was prior to computers. So yes 9 second gas p***es are more than possible.
    T-man mentioned E-85 which I think is interesting. NASCAR which is little more than a flying circus these days is using ethanol. I think that if one of us showed up at an NHRA event in a gas cl*** car with E-85 we would probably have to drain our tank and p*** tech again. Maybe not, I do know that they actually check your alcohol when you race and there is a specific blend of alcohol that you are required to run. it stands to reason with E-85 available at the pump that they will probably be checking gas as well.
    No one has yet mentioned match races. Back in the day it is said that the match bash racers ran on alcohol. Which may very well be true. The cars they were racing were considered to be "g***ers" and when they were cl*** racing they ran on gas and they were "g***ers".
    Match racing was window dressing for lack of a better term. The cars were normally paid to show up and they were there to draw a crowd. There were big rivalries as well as big sponsors (like cam shaft companies). One may even call a match race a grudge race.
    Match racing is not cl*** racing. There is a score to settle and whatever it takes. There is no real prize other than bragging rites and pleasing the crowd. No different than bringing in a wheel stander in, or maybe better said not much better than bringing a wheel stander in.
    I think that if one is going to be running "g***er" races with some running on alcohol there should be a distinction made. A gas cl*** and a fuel cl*** in "g***er styled" cars.
    If the modern racer cannot get a car into the 10s on gas then there must be an awful lot lost to today's tunners. The old fellas did it in their garage without dynos, they maybe had a sun bench.
    Edit damn it: Larry mentioned match race cars while I was typing.
    Alchol runs cooler than gasoline. Even when you run it through a carb. It just burns cooler.
    One old trick that the blower guys used to do was spray their fuel charge with alcohol. it did two things it cooled the fuel charge on the way in and I effectivly cooled the combustion chamber. Some fellas mistakenly believed it was to boost octain but it was actually used as a coolant.
  4. Mike51Merc
    Mike51Merc
    Isn't gas the whole point of a g***er?
  5. Prior to funny cars which became the demise to g***ers they ran on gas and were a draw to the ticket gates because they were cars that the general public could identify with.
    Early on the cl*** was called gas coupe/sedan. It was a step up from stock cl***. You were allowed to set the engine back and run whatever engine/transmission combo you wanted. Minor suspension upgrades were allowed etc. They were actually a street legal cl***.
    They ran on gas because that it what Joe Public ran in their car.
    It eventually became a pro cl*** and more modifications were allowed but it was still a gas cl***, at least in the NHRA it was a gas cl*** and was accepted as a gas cl*** by most sanctioning bodies. Some sanctioning bodies from what I have been told eventually allowed alcohol. The NHRA never made it a fuel cl***.
    Perhaps the modern day equivalent to what we know as a g***er is pro-mod. I believe it is a gas cl*** but I can't really say that it is. Maybe one of the still active NHRA racers can step up on that one.
  6. squirrel
    or someone who likes to google...from the wikipedia entry for Pro Modified:
    "Both nitrous and turbocharged cars use high octane racing gasoline as fuel while supercharged cars use methanol as a fuel."
  7. Larry T
    Larry T
    I guess it depends on what era and if you are talking cl*** legal. Yea, if you were running NHRA cl*** it was ONE of the points, but no where near the whole point.
    And as far as gas and fast cars go, gasoline is ONE of the rules of modern day Pro Stock. Although Warren Johnson got his wrist slapped at a fuel check once and was heard to say sarcastically "I guess they want us to run it the way it comes out of the can." I think Glidden was pretty creative too.
    Most Comp Eliminator cl***es are restricted to gas too.
    I've got a buddy who runs a 4.70 (1/8) doorslammer on racing gas.
    Larry T
  8. Bean Dip
    Bean Dip
    Thanks Lippy that's a cl*** move and I appreciate it.:cool:
  9. lippy
    lippy
    from Ks
    Bean, I've been called a lot of things but cl***y ain't one of them.:p Thanks, that's a first for me.:D
  10. Bean Dip
    Bean Dip
    ---gas car can run with the alcohol cars it is just that alcohol runs much cooler...especially in blown cars like mine and that's a big deal. My car is actually set up to run pump gas on low boost(6.8:1 static compression) but I converted to alcohol because the car was running too hot for my taste. 230+ at shutdown and then I would need to be towed back to the pits. Now my car runs about 50 degrees cooler and I just drive it to the line and back to the pits. Another HUGE advantage is the cool "charge" alcohol provides. This is so important on the blown cars because they are already making so much heat when you start to really spool the blower. When I get back to the pits my blower is frosted up like as if it had been packed in ice.
  11. lippy
    lippy
    from Ks
    Larry T, a well known Fuel funnycar racer friend of mine told Warren Johnson once as Warren didn't care for funnycars, "I've jumped out of burning funnycars going faster than your car will run" :D
  12. Mazooma1
    Mazooma1
    Really?
    they ran gas
    A "g***er" running fuel would have been in the fuel altered cl***....
  13. falcongeorge
    falcongeorge
    from BC
    Recently, I have been wondering if it was possible for this place to get any dumber. That question has just been answered...
  14. lippy
    lippy
    from Ks
    The question is not what the cars ran in gas cl***, we know it was gas. This is a traditional hotrod site. I mean my goodness you can't run that oil pressure guage, it's too new, or Those front wheels came out in 66 not 64. Why is the practice of running alky in a g***er race car ok here? I've heard people pick on people for the damndest things here but no one has said anything about this. This is the question I have been asked and I don't know. Falcon George are you serious? Lippy
  15. lippy
    lippy
    from Ks
    I guess we will let this one go the way of the dodo bird. :D
  16. Larry T
    Larry T
    Pretty simple answer to the gas in g***er question. Yes, if you were running in the Gas Coupe Sedan cl*** at a NHRA sanctioned event you had to run gas up until the cl*** was dropped.
    Now to prove you can find the "facts" to back up just about any claim about any subject.
    "Tom Prock and Jay Howell campaigned the F Troop in 1968 and 1969 in an outlaw AA gas circuit formed by the Hill brothers, along with Jim Shores and Chuck Finders. These 99” wheel based “g***ers” ran in the mid to low eight second range on as much as seventy five percent nitromethane."
    Just pick a side and argue until you're blue in the face.
    BTW, I'm on the side of the cl*** legal g***ers definition (at least for today) with black and white rules.
  17. Bean Dip
    Bean Dip
    The p***ion nostalgia racers have is what fuel these cars and not the type of fuel they put in there tanks. Drag racers are crazed by nature but nostalgia drag racers play by a whole different set of rules. The fuel we run may have changed through the years but that lust for speed and danger is still there. I don't care if you're running karo syrup in your g***er just line that ****er up! Viva la Gas House Gang!
  18. squirrel
    I guess it's like the "street car" races where every car there is trailered.
  19. zman
    zman
    from Garner, NC
    If it's not running gas then it is not a g***er. :rolleyes:
  20. falcongeorge
    falcongeorge
    from BC
    No no Zman, "g***er" is a state of mind. Drink the kool-aid.:rolleyes:
  21. zman
    zman
    from Garner, NC
    Not gonna do it. I've also been thinking about building a g***er with, and get this, no straight axle, and not raising the front end. :eek:
  22. lippy
    lippy
    from Ks
    We may just be getting old guys.:) Seems anything goes anymore. I still miss when g***ers ran gas and men steered wooden ships. LOL.
  23. lippy
    lippy
    from Ks
    :eek::eek::eek: Oh no!! But surely you will cut the rear wheel openings out?? LOL.
  24. Bean Dip
    Bean Dip
    You don't know your ***. But that's ok...right now your surrounded by a lot of other folks that don't know any better either.Dragstrip is a different story. Bring your junk, run your car then you can run your mouth. That's how it's done.
  25. squirrel
    I have one of those.
  26. lippy
    lippy
    from Ks
    I'm building for a new cl***. Lippy
  27. zman
    zman
    from Garner, NC
    You're funny, but it seems that you are the one that does not know their ***.
    Look in the rules for the Gas cl***'s and you'll see that very first thing is...
    "Must run service station pump gasoline"
    Here are the 56 gas rules if you like...
    http://www.thehemi.com/gallery/main.php?g2_itemId=3968
    That's how it's done. You can try to rewrite history but it just doesn't work. Maybe learn a little before running your mouth.
  28. falcongeorge
    falcongeorge
    from BC
    And most of the guys *****slapping you on here HAVE done some drag racing. Some of us have even run tens without alky.:rolleyes: Some of us have done it on pump gas...;)
    What a complete crock of **** this thread really is. You guys should be embarr***ed. REALLY. I am dead-serious.
  29. H.G. Wells
    H.G. Wells
    Lippy, just to confuse this issue even more....
    I custom blend a racing E85 for a guy who runs a cl*** that has to use gas. Can't run methanol, but can run an ethanol blend. E85 is cl***ified as gas. He also does not have to have all the safety equipment we run in the alky cars.
    But to answer your question, methanol.
  30. lippy
    lippy
    from Ks
    I am truly sorry for the turn this thread has taken. I started the thread, I'll take the lashings. Lippy
