Single barrel holley carb identification
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by kerm55, May 6, 2008.
  1. kerm55
    kerm55
    from pasadena
    Please help, I'm restoring an older jeep f-head, it came with a Holley single barrel carb with the following numbers: List 2273-2 AND C2TE-9510-L. On the base it has 12B 1958. On the barrel it has M5. and finally on the area with the holley name it has 6R 2198 B. I would really like to find out where this carb came from, are rebuild kits still available, and how it works so I may make simple adjustments.
    Thank You very much - Kevin
  2. Frank L. hughes
    Frank L. hughes
    Kevin, post questions on message board, it will get you an answer faster.
