Technical Single ignition wire firing each bank of V-8
Discussion in 'The Hokey Ass Message Board' started by Dave Downs, Jul 4, 2024.
  1. Dave Downs
    Dave Downs
    from S.E. Penna
    I remember seeing what I think was T-bucket with a Hemi in a magazine (1957/58) with a single ignition wire to all 4 spark plugs on each bank.
    I’m sure this was done in an effort to ‘clean up’ the engine.
    Would an engine run with this setup? Each plug would fire 4 times every revolution (***uming standard points type distributor) and which ever piston was on a compression stroke should fire. This would depend on an ignition system strong enough fire 7 ‘dead’ plugs and 1 under compression. I don’t think it would have run well but the car seemed to be a show custom.
    This is a memory from a long time ago and I may even have asked this question before …. but don’t know if I got an answer…..
    Anyone got thoughts on this or can possibly confirm this car actually existed?
  2. Mike VV
    Mike VV
    from SoCal
    Seems like an odd experiment.
    But...not maybe so impossible.
    See the MSD (multiple spark discharge) box's (and a couple others), that fire about six times, in about 20° of crank revolutions, for every "single"...firing order at idle. NOT just one time.
    This continues up to about 3000 rpm, when the system reverts to a single, high energy spark like "normal".
    See the MSD instruction manual(s) for more information.
    So yeah, I'd guess with a much modified distributor and or external control box with lots of diodes transistors and capacitors, it could work.
    BUT, it seems that at slightly higher rpms than just idle, the spark could become a BIG problem which plug that it was supposed to fire at what RPM !
    Mike
  3. twenty8
    twenty8
    ^^^ ... not in 1957/58...
  4. Unkl Ian
    Unkl Ian
    I remember it.
    Pretty sure it was not a Hemi.
    Might have been a SBC.
    Kinda sounds like a crude Wasted Spark System.
    seb fontana likes this.
  5. tubman
    tubman
    Who said Show Cars had to run?
    A lot of two-cylinder snowmobile engines do it.
    Desoto291Hemi likes this.
  6. Fordors
    Fordors
    It was on a nail head Buick in a Model T, this photo was on the cover of the Hot Rod Yearbook No. 6. The car was featured in Hot Rod magazine but no idea of which issue and I never saw the ignition system explained.
  7. sdluck
    sdluck
    I thought it was a buick
  8. G-son
    G-son
    from Sweden
    No, that doesn't work. Any time you put multiple spark plugs in parallel you will only get spark on one of them, the one the spark can jump across easiest, and that will not be any cylinder under compression.
    Something else is going on there.
    Two plugs on one coil is a waste spark system, with both plugs wired in series. Relatively common, but that's only two plugs per coil, no more.
  9. d2_willys
    d2_willys
    from Kansas
    Sounds like a disaster waiting to happen. Every 45 degrees you have a spark. So, two cylinders are properly timed in reference to tdc1. (One will be 180 degrees away from TDC 1). But just think, one or more cylinders will be in the compression stage. I would think that ignition anywhere in a compression stage would ignite and send the piston back down or possibly slow or kill the engine rotation. And what happens with advancing the spark? Love to see one running.
    '29 Gizmo likes this.
  10. Unkl Ian
    Unkl Ian
    If it was actually usable, someone else would have done it again since then.
  11. goldmountain
    goldmountain
    I remember Hot Rod ran an article about that setup in the issue that had the T featured.
    seb fontana and Unkl Ian like this.
  12. RodStRace
    RodStRace
    There was an explanation of this in one of the bucket threads when it came up. I think it was Bucket Of Ugly, but not positive.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
  14. '29 Gizmo
    '29 Gizmo
    from UK
    I see a lot of things on show cars and think WTF. I treat it as art rather than competent engineering.
    BTW it could be made to work if the crank and cam were configured to act like I giant V Twin.
    Unkl Ian likes this.
  15. brading
    brading
    I seem to remember that Hot Rod magazine done another article on this idea in the 60's but I thought that V8 flathead. The reason I say the 60's is I would not have bought Hot Rod mag before then.
  16. Driver50x
    Driver50x
    Could that be four separate pieces of thin wire covered to look like one?
  17. G-son
    G-son
    from Sweden
    That would be my guess.
  18. theHIGHLANDER
    theHIGHLANDER
    For anyone interested, on topic, my 3cyl Rotax Type 809 fires all 3 every time. And point of fact H-D V-Twin engines fire both every time and have done so for quite some time. Not sure what they do today with all the electronics. I'd say the above was done strictly for eyeballs, and maybe in fact was separate hidden small wires. I can't square it up in my head on anything other than maybe a 180 crank.
    flynbrian48 likes this.
  19. flynbrian48
    flynbrian48
    HD's indeed use a "wasted spark" ignition, although they've got a separate plug wire to each plug. They fire both, and it does, as one would think, cause a little chaos in the cylinder that's not on the compression stroke, as there's some unburned fuel left. A Harley engine is pretty much all chaos anyway, it's part of the charm of a tractor engine in a motorcycle...;)
  20. ClayMart
    ClayMart
    I'm guessing that's also at least part of the reason for the "puh-TAY-toe, puh-TAY-toe, puh-TAY-toe" exhaust sound at idle . . . ?
    :rolleyes:
    05snopro440 and theHIGHLANDER like this.
  21. theHIGHLANDER
    theHIGHLANDER
    They have a dead stroke as in "bang-bang puff-puff" which is like flyin said above, farm implement stuff.
    427 sleeper and 05snopro440 like this.
  22. 05snopro440
    05snopro440
    My uncle had a John Deere D I would drive as a kid. It indeed sounded a lot like a Harley.
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    This is a nailhead converted to diesel, this has been discussed here before
  24. Fordors
    Fordors
    I’d be interested in reading that thread but l’ve searched and can’t find it. Maybe I’m using the wrong search terms, can anyone help?
  25. theHIGHLANDER
    theHIGHLANDER
    Never occurred to me, makes all the sense in the world.
    Moriarity likes this.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, there is an injector pump being driven where the distributor would have been....
  27. jaracer
    jaracer
    But like spark plugs, you can't plumb diesel injectors in series unless you have some way to trigger them. They need to be timed just like a spark plug.
    I do seem to remember reading about this engine in one of the hot rod magazines and they said it did run. There was an explanation of how it worked, but I don't remember it. It did have something to do with ignition only occuring when the cylinder pressure was correct, but that doesn't make sense either.
    When I worked for the Dodge dealer, we had a Snap-On ignition box that gave out a constant spark. You could take an engine with a dead ignition system, pull the coil wire out of the distributor, plug in the wire from the Snap-On box and start and run the car. However, you still had the distributor sending the spark to the appropriate plug.
    Driver50x and seb fontana like this.
  28. chicken
    chicken
    from Kansas
    Maybe what the picture shows are glow plugs. The diesel fuel could have a delivery system that isn't shown. All that stack stuff in the valley-what's going on there? True diesel engines don't have throttle bodies or throttle plates to control engine speed.
    427 sleeper likes this.
  29. seb fontana
    seb fontana
    from ct
    Yes I believe it was in HRM. I remember Konig as being the name of the system. Should be in HRM archive's.
  30. I agree. All the plugs won't fire equally. It's Vegas odds which plug would fire. "Electricity takes the path of least resistance". This is why distributors have "points", one per cylinder.
    Edit: I'm sure this has been covered already..... but I'm leaving it here anyway. :cool:
    G-son likes this.
