single leaf gasser vs parallel leafs
Discussion in 'The Hokey Ass Message Board' started by v8nova64, Nov 13, 2012.
  1. v8nova64
    v8nova64
    from !!
    delete
  2. 500 single
    500 single
    I think you're going to have to pick either "works better" or "looks cooler". You won't get both.
  3. 1971BB427
    1971BB427
    from Oregon
    Parallel leafs work better when you start getting the nose up in the air.
  4. kwoodyh
    kwoodyh
    Parallel will work the best for your application.
  5. 50dodge4x4
    50dodge4x4
    ^^^I agree. ^^^
    The transverse spring looks goofy on a raised car, in my opinion.
    Gene
  6. Ghost28
    Ghost28
    And they look better, and in my opinion look stronger on a g***er
  7. Rusty O'Toole
    Rusty O'Toole
    Parallel leafs work better. That is why 99% of car makers used them. Transverse leaf is cheaper ( you pay for 1 spring instead of 2). That is why Ford used them.
  8. rustang
    rustang
    ^^^^ +1
  9. How heavy is the car?, the cross leaf doesn't work as well as a parallel setup in a heavier car.
  10. HOTRODPRIMER
    HOTRODPRIMER
    With the user name I would think it's a Nova,,,I believe the parallel springs would handle and drive better with the nose in the air. HRP
  11. check-out how manufactures of frt clips do it. How thick is thick -walled tubing and your 1/2" thick mounting flange is too heavy and you will have to run from the top mounts on the firewall to the front of the lower rails. there have been several nova's built on this forum do a search to see how they did it, will save you some headaches
  12. II FUNNY
    II FUNNY
    I ran 2x4x.125 wall tube when I built mine, but I don't think that 2" square tube would be a problem as long as you triangulate it to the upper factory firewall mounts.
  13. II FUNNY
    II FUNNY
    This one is from the first instant funny car the Bill Thomas "NOVEL NOVA"
  14. II FUNNY
    II FUNNY
    There a few more pics in my profile. I would have gladly done some measuring except that I sold it this past summer.
  15. 296moon
    296moon
    from england
  16. 296 V8
    296 V8
    from Nor~Cal
    yeah one spring looks dumb and who would want 30lb's less on the nose.
  17. 296 V8
    296 V8
    from Nor~Cal
    Shackles in the rear are preferred if you haven’t mounted anything yet.
    Shackles in front need to angle forward … the ones in the photo are bound up and wrong.
  18. 296 V8
    296 V8
    from Nor~Cal
    Easiest way to describe it here?
    They should angle the opposite of the ones in the photo.
    The ones in the photo are likely to flip up under the right conditions
    Adding leaves will only change the shackle angle if they change the arch of the main leaf … more arch = shorter eye to eye dimension.
  19. kennkat
    kennkat
    I hope you do not mind... Here is your photo crudely "photo shopped" into what I see as the proper shackle angle.... :)
  20. kennkat
    kennkat
    Yes, you got it..:)
  21. 296 V8
    296 V8
    from Nor~Cal
    If its all new stuff ?
    Id go for just a bit past vertical …. You will be adding weight and springs will settle / flatten a bit
  22. kennkat
    kennkat
    Yes, I was speaking of the Fully Loaded angle, new springs may be slightly less, as stated .:D:D:D
  23. SmokinBill
    SmokinBill
    Here's a good shot of before and after weight loaded on spring and shackle
  24. 296 V8
    296 V8
    from Nor~Cal
    v8nova64
    Are you Elvis38 on the other site?
  25. rustang
    rustang
    Mine is pretty close to what SmokinBill has in his picture....When i initially set mine up I had more angle than what I liked when all the weight was on the front (I would stand on the front bumper and bounce the springs would just touch the bumpstops) this was the shackels at 45 deg...my front frame rails tilt down slightly...
    What I did was take the springs out and a 1/2" of more arch put in them and it solved the problem (if you could call it one).... shoot for about 30 deg. and you will be golden with those small speedway style shackels....
    Tom
  26. 1971BB427
    1971BB427
    from Oregon
    I wouldn't go 45 degrees loaded. I'd go something past straight up, but maybe 10-15 degrees, so you have plenty of movement and the shackle wont flop over against the frame.
    If you start straight up like Smokin Bill's Nova, and have stiff enough springs it will settle to about perfect. But if the springs are too soft then you need to even be a bit less than straight up to end up perfect. A BBC might also create a bit more weight, and settle more too, so if you can just weight the frontend with your engine, or enough static weight, then you can tack things together and see how it all sits.
    You never did mention what wall thickness your 2" round tube is. Wall thickness, type of material, etc. will all determine if it's stout enough. If you're going to use typical Nova firewall braces also, then that factors in too. Might be easier to determine if 2" OD tube is enough if you could answer the questions, and maybe show how you're bracing it all to make the subframe.
  27. langy
    langy
    If you mean the axle yes but 1/4" thick wall seamless
  28. langy
    langy
    60 dgrees would be better in my opinion
  29. swade41
    swade41
    from Buffalo,NY
    30 lbs less for the spring but add the weight of two hairpins so your are even again.
    We have guys with both types and both types get down the 1/4 mi. in the 10's
  30. Lytles Garage
    Lytles Garage
    With a transverse spring, you can kick the front wheels out a couple of inches without the front springs sticking out past the bumper. Chris
