Hot Rods Single Piston Calipers
Discussion in 'The Hokey Ass Message Board' started by 340HilbornDuster, Mar 25, 2015.
  1. 340HilbornDuster
    340HilbornDuster
    So i got these single piston corvette calipers...
    I was told single piston = need brake booster...?
    Four piston = no nned?
    Anyone experienced .... do i really need it for these calipers?
    My Hilborn manifold doesn't have a vacuum port...!
    I made a small one 3/16 spider to all ports for vacum to the "computer thingy"
    Probably not big enough for brake booster?
    Mahalo
    Tommy
  2. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    You don't need a booster for them. Just the correct master cylinder.
  3. Hnstray
    Hnstray
    from Quincy, IL
    The number of piston in the caliper is not the deciding factor in whether you need a booster. Among the factors that collectively will determine whether you need or want a booster, or not, are.....the total area of the caliper pistons and wheel cylinders versus the master cylinder bore size, the brake pedal ratio, the brake rotor and drum diameters, the friction material of brake pads/shoes, weight of the vehicle, tire sizes and your satisfaction with the pedal pressure required without a booster.
    It is entirely possible that you will be satisfied with the results of your brake system without a booster, but very difficult to predict with certainty, given the variables involved. Put it together and try it.
    Ray
  4. Do a search for Corvette brakes to find what master cylinder was used with the calipers you have. I would guess there were manual and PB options for the YOM of your calipers.
  5. 340HilbornDuster
    340HilbornDuster
  6. 340HilbornDuster
    340HilbornDuster
  7. 340HilbornDuster
    340HilbornDuster
    Called them...They pulled the product...(some problems)...re-engineering...
    Price?...depends on the parts they're gonna use....call us back in 5-6 weeks...
    I guess I'll have to find something else...
    I probably just try a master cylinder with a good ratio...make sure pedal ratio is good...etc.
    ...we'll see?
    Thanks for all the input guys!
