Technical Single stage paint help
Discussion in 'The Hokey Ass Message Board' started by Padtech, Apr 25, 2017.
  1. Kirby had the turbine system way back in the day. I guess The guns have come a long way since.
    I haven't used one , so How much do you need to thin the materials? Your comment makes it sound like it's beyond the manufactures specs.
  2. Blue One
    Blue One
    from Alberta
    I've been told that using the tip size recommended by Fuji for my particular gun that I will be able to spray the Acrylic urethane or epoxy primer without thinning just as if using a compressor supplied gun.
    I guess I will find out :)
    120mm and loudbang like this.
  3. What's the tip size they recommend
  4. Blue One
    Blue One
    from Alberta
  5. For water in my old compressor,I've opened the drain valve slightly to eliminate the water issue during a paint job.
    My new compressor has an automatic bleeder.It bleeds my tank every 10 min for about 3-5 secs. I also have an expensive water separator on the hard line.
    Glad you solved you problem.
  6. Blue One
    Blue One
    from Alberta
    That's good to know.
  7. 120mm
    120mm
    from Iowa
    Don't know about the specs, but definitely more than the instructions on the side of the can. I use a drip cup which has timed flow to determine if it's been reduced enough. Basically, you add thinner, stir, then dip the drip cup into the paint, and time how long it takes the cup to empty. I'm operating from memory here, so some paint you thin to 6-8 seconds and another you thin to 13-15 seconds. Don't remember which.
    Whoa. That would be kinda cool. We used to shoot a bunch of urethane/epoxy on airplanes and I seem to recall thinning it a bunch. That was over 10 years ago, though. My last paint job I did in 2015 and did an old 4x4 with enamel and it was thinned significantly past the instructions on the can. I am really interested in how your paint turns out.
