Sins of Steel 2013
Discussion in 'The Hokey Ass Message Board' started by loveoftiki, Jan 22, 2013.
  1. loveoftiki
    loveoftiki
    from Livonia,Mi
    A week from right now folks....I hope I got a car back together in time!
  2. jdubbya
    jdubbya
    I will be gathering at the gas station, at the corner of Grange Hall and Dixie, about 8am. We will fuel up, purchase food and drinks, and be headed to Davisburg about 830-840am, for the 20 minute ride there. The weather kept our caravan numbers down last year, but it has been known to reach 25 plus in years past. Either see you at the station, or at the show... should be a great time as usual!
  3. dragass
    dragass
    The Lead Kings will be there full force.
  4. Woody94
    Woody94
    from Holly, MI
    Can't wait for this one!!! Woo hoo, only 1 week to go!
  5. loveoftiki
    loveoftiki
    from Livonia,Mi
    Spent the day trying to exercise the demons from my F100.....might be minivan city for me!
  6. captain scarlet
    captain scarlet
    from Detroit
    Tiki. If you can get to me I have a spare seat
  7. Planning to bring my Riviera. Not sure yet if any other SuspectS are going.
  8. jack_pine
    jack_pine
    from Motor City
    What time do the gates open for registration? I hope to be there with my '64 A-100 van
  9. loveoftiki
    loveoftiki
    from Livonia,Mi
    Line up after 9...see ya there!
  10. loveoftiki
    loveoftiki
    from Livonia,Mi
    I hope to get one of the cars figured out by then...if not I can grab a ride with someone.. I appreciate the offer..I think the F100 may have been a bad coil.. would run fine and then act like it had no fuel . but changed all filters got fuel in the filter and carb, pulled line coming off tank and got gas there too... hmmm..changed the coil out but haven't got to test it out yet.had a bud with a FE that did the same thing, car would run great for about 10 minutes and then start cutting out..replaced the coil.. all good
  11. You'll have some company on the trip brother.....the E.L.T.A. Disciples of Speed are cruising down with ya......should be a blast.
  12. flatheadpete
    flatheadpete
    from Burton, MI
    Jenny and I are gonna take our time this year. Leave about 9-9:30ish and roll down Dixie. See you all there!
  13. MrGasser
    MrGasser
    from DETROIT
    Not trying to be a Gloomy Gus, but, Weather Channel is saying a 60% chance of rain, with the potential for severe thunderstorms...
  14. loveoftiki
    loveoftiki
    from Livonia,Mi
    Thanks for the update Randy... I expect to see you there in full weather man get up
  15. safari-wagon
    safari-wagon
    Weathermen get paid a lot of money to be wrong most of the time...
    SinglefingerSpeedShop.com
  16. MrGasser
    MrGasser
    from DETROIT
    Yes...yes they do!
  17. flatheadpete
    flatheadpete
    from Burton, MI
    One of just a few careers that people get paid to guess.
  18. Sounds like the gas cap may not be vented.Most of the bad coils i've had either quit completely or break down under hard acceleration.
  19. loveoftiki
    loveoftiki
    from Livonia,Mi
    Pulled the cap off...no change. I'm hoping coil cause that's when it would stammer..higher RPM and after the truck warmed up. Friends 64 Merc did the same thing, thought it was fuel system, plenty of fuel in the carb and coming from the pump, after 10 minutes the car would fall on it nose, put a test light on the coil when the car warmed up the coil woul die.. I don't know how old the coil is on the ruck so it got replaced anyway
  20. My brother-in-law had a real weord one with his 73 Ranchero one time.Had a 302 2v and it would start and idle fine.The minute you started driving it and tried to accelerate it fell flat on it's face. He worked on it for weeks with my other brother-in-law who was a mechanic and they were tearing their hair out trying to figure out what was wrong.
    I stopped in one day while they were working on it and noticed the problem immediately.Boy were they pissed when I fixed it! Turned out the hood insulation was loose and getting ****ed into the air filter when you accelerated.Ripped out the hood pad and it was fine!
    Sometimes you just need another set of eyes on it to cure the problem.
  21. Rochie
    Rochie
    Tiki,
    make sure you check the lead from the points to the coil through the dist. body. The vacuum advance pulls and lets off, so the wire has to do the same thing. I have found a number of times the wire looks good but has a break in it from the movement. Check the ground as well from the points plate to the body of the dist.
    See you boys on Sat.
    Roch
  22. raceron1120
    raceron1120
    I don't know what engine you're working but yeah - if it's a Ford, that lead wire going thru the distributor case would wear thru the rubber insulator and rub on the case & ground out. You can't see it unless ya take it out, they usually wore thru on the bottom. Sold a lot of 'em back in my Ford Parts guy daze. . . Good luck finding the gremlin!
  23. loveoftiki
    loveoftiki
    from Livonia,Mi
    No points got an accel conversion in it. 352 FE is what I'm working with. Hoping to mess with it tonight. Rain rain go away ha a
  24. koolkat269
    koolkat269
    You need a new distributor. I had this same problem last summer in my 34. Would start up and run fine for awhile then cut out. Had a mallory distributor in it then rebuilt a stock one to an HEI. Haven't had a problem since. Driven it 1000 miles so far this spring with aa 800+ mile round trip to Tourque Fest.
  25. Rochie
    Rochie
    Hey Tiki,
    on another note...are there any restrictions on cars at Sins of Steel... Absolutely NO billet etc.
    If it's still looking like 70/80% chance of rain I might not want to be in the roadster. Just makes for a really looonnng Day.
    Is this OK????
  26. loveoftiki
    loveoftiki
    from Livonia,Mi
    Well the traditional police would arrest you for those wheels...sorry... I cant promise anything....and rules are rules....sorry..:eek: this is why working the gate can be tough.. I dig the car..just doesn't fit the show guidelines, and personally I don't think some of the over the top "hey look at the turd I put a bunch o ******** on to make a rat rod" should get in either. Telling someone ahhh no your pride and joy doesn't get a p*** is tuff. Sorry..maybe drive it over, see what happens, there's always spectator parking...plus ya can say ya came over in a old car...
  27. Rochie
    Rochie
    Well, Jeeezzz,
    If I had only gotten the steelies done I could've stayed dry. We'll have to see what the weather brings. I've been wet in this before but it's a 3.5 hour drive home
  28. flatheadpete
    flatheadpete
    from Burton, MI
    Roadster in the rain......Wish I still had mine. See everyone Sat. Be safe.
  29. loveoftiki
    loveoftiki
    from Livonia,Mi
    Duct tape some hub caps over the wheels......done! Your in haha
  30. D-Day
    D-Day
    from NW Ohio
    Looking forward to it; if I don't frag anything before getting there.
