Sitting and rotting....OT Cars
Discussion in 'Off Topic Hot Rods & Customs' started by pigIRON63, Aug 6, 2024.
  1. j hansen
    j hansen
  2. j hansen
    j hansen
  3. j hansen
    j hansen
  4. porkshop and Deuces like this.
  5. chrisp
    chrisp
    850 made total between the Z and PL models including soft top pickup models as well as the hard top model one as pictured.
    So it's a very rare one but they're cheap, you ain't gonna break the bank buying one, restoring it is a whole lot different story.
    About 10 years ago I used to drive a blue PL pickup.
  6. 65pacecar
    65pacecar
    from KY, AZ
  7. 65pacecar
    65pacecar
    from KY, AZ
  8. 65pacecar
    65pacecar
    from KY, AZ
  9. Maverick Daddy
    Maverick Daddy
  10. porkshop and SS327 like this.
  11. Bandit Billy
    Bandit Billy
    I don't have a clue what that is but I like it. Soooo much potential. Sort of a Sean Connery meets Bob Falfa mix up
    porkshop, Deuces and deathrowdave like this.
  12. j hansen
    j hansen
    Skärmavbild 2025-04-29 kl. 06.20.36.png Skärmavbild 2025-04-29 kl. 06.18.59.png Skärmavbild 2025-04-29 kl. 06.18.42.png
  13. Maverick Daddy
    Maverick Daddy
    It's rough... with a capital R. This judge is 20250414_163912.jpg on the same property....
  14. Squablow
    Squablow
    I would love to drive around in that Panhard with the camper shell thing on the back, it's so foreign it's almost alien. Like they say, the French copy no one, and no one copies the French.
  15. partsdawg
    partsdawg
    from Minnesota
  16. chrisp
    chrisp
    You'd be surprised how well the 850cc runs until you hit an incline. But I can tell you that the most powerful ones have a top speed of 100mph and a standard sedan can run 80mph all day.
    Then you can punch them out to 950cc convert them to twin spark plugs with twin carbs, there even was an after market blower for them.
    Race only can be bored up to 1.2L but the engine don't last. With a lot of machining some people made 4 valves heads too, ultra rare to find nowadays.
    The best bet is to find an aluminum Z1 and throw in there a 950cc, modify the rear axle and front suspension like the one found on the DB HBR5 or the CD so it doesn't oversteer as much, disc brakes from a PL24.
    That makes quite a sleeper : 710kg with the full upholstery and 90/95hp.
    chryslerfan55, porkshop and Squablow like this.
  17. j hansen
    j hansen
  18. James D
    James D
    I was wondering about doing what the 2CV guys do and replacing the motor with a BMW boxer motorcycle engine. Some of those are 120hp iirc. They're a good bit heavier than the Citroen, but you'd have far better aero. Would probably make for a pretty quick car.
    chryslerfan55 and porkshop like this.
  19. j hansen
    j hansen
    Deleted,wrong thread!:oops:
  20. chrisp
    chrisp
    I know there were some people putting the BMW rotating ***embly inside the Panhard engine block, the last l heard of them some years ago they were making the oiling system with tubing because the Panhard was just a rudimentary splash oiling because it's using needle and roller bearings instead of solid bearings like everybody else and you can't pressurize them.
    By the way the Panhard engine is way more efficient than the 2cv. When Citroën bought Panhard in the 60's they tried to simplify the Panhard engine with catastrophic results.
  21. James D
    James D
    It was a good little motor for the time. Incredible to get 60hp (?) from such a small thing.
  22. SS327
    SS327
  23. partsdawg
    partsdawg
    from Minnesota
    Which ones?
  24. 65pacecar
    65pacecar
    from KY, AZ
  25. Deuces
    Deuces
  26. gene-koning
    gene-koning
    Can you imagine what the stuff under the tarps look like? Those tarps tends to trap the moisture under the tarp.
  27. j hansen
    j hansen
  28. j hansen
    j hansen
  29. j hansen
    j hansen
  30. What in the Sam hill is going on here?!?, would one of youse hoodlums please rescue this thing? Please?
    SS327 likes this.
