Sitting and rotting....OT Cars
Discussion in 'Off Topic Hot Rods & Customs' started by pigIRON63, Aug 6, 2024.
  1. 65pacecar
    65pacecar
    from KY, AZ
  2. j hansen
    j hansen
  3. SS327
    SS327
  4. 65pacecar and porkshop like this.
  5. Deuces
    Deuces
    Kinda looks a little narley dude.....:confused:
    65pacecar and chryslerfan55 like this.
  6. j hansen
    j hansen
  7. j hansen
    j hansen
  8. j hansen
    j hansen
  9. j hansen
    j hansen
  10. Deuces
    Deuces
  11. 65pacecar
    65pacecar
    from KY, AZ
  12. j hansen
    j hansen
  13. chryslerfan55 and porkshop like this.
  14. Squablow
    Squablow
    chryslerfan55 and 34 GAZ like this.
  15. j hansen
    j hansen
  16. Wanderlust
    Wanderlust
    IMG_2081.jpeg G body sleeper material, most likely be grabbing this
  17. Aussie muscle, big bucks now. 1968 to 1971 Holden Monaro GTS 327 & 350.Also came with a straight six 186 cu in.
  18. What the hell, one more pic, Ford Killer :D:cool:
  19. Zuffen
    Zuffen
    from Sydney
    This was way before Drifting became a thing. The Monaro was simply an Homogenous design, where it all just worked together.
  20. j hansen
    j hansen
  21. j hansen
    j hansen
  22. j hansen
    j hansen
  23. j hansen
    j hansen
  24. j hansen
    j hansen
  25. Wanderlust
    Wanderlust
    IMG_2081.jpeg Pulled the plugs, shot of wd40 , rigged up remote fuel, cleaned contacts, checked distributor , hooked up battery and a bit of fuel in the carb and line / filter, turned maybe 3 revolutions and fired off. Of course all was not golden , fuel line between filter and pump had a crack and leaked, m/c reservoirs empty, filled em up and just started to get a pedal when something let go and both front tires are rotten and won’t hold air. But it’s not sitting and rotting any longer, if I can help it :)
    Didn’t run it very long as with the front tires flat the exhaust was down in the gr*** and it’s dry as a popcorn fart here, starting a gr*** fire wouldn’t earn me any brownie points, plugs were black and fluffy and as long as I ran it I could see it’s a pack a day smoker
  26. Let’s see, vehicle, check, build plan, check, engine, pending, rear axle, pending, suspension, check, brakes, pending, exhaust, check, mufflers? You don’t need no stinking mufflers! Paint, it’ll buff out, hehe, approval from da boss, double check, seatbelts, check, insanity defense in case it all goes wrong, check. Carry on.
    porkshop likes this.
  27. j hansen
    j hansen
  28. j hansen
    j hansen
  29. j hansen
    j hansen
