six cylinder header collectors
Discussion in 'The Hokey Ass Message Board' started by edweird, Apr 8, 2010.
  1. edweird
    edweird
    my dad wants me to make a set of headers for his 41 stude. its got the 245 six from a 54 truck. do yall know of anyone who makes the three pipe collector? thanks ed
  2. Blown 26
    Blown 26
    I build custom headers but I cant seem to find anyone who builds them. Shouldn't be hard to make. Take 3 pipes that will slide over the pipes you have angle cut them length ways with an upright band saw and weld the three halve together. Should look like a 3 leaf clover on one end with a point on the other. Decide on what size exhaust your are going to run and cut off about 5 inches of that slide it over the point mark it cut off the excess of the clover and sew it up and you then have a 3 pipe collector
  3. CrkInsp
    CrkInsp
    from B.A. OK
    You might try Speedway or Summit.
  4. I have a great magazine tech showing the way headers were built for years. I think it is actually in an old SRM. you start with a round collector and a solid mandrel the diameter of your tubes. and form the collector to fit your tubes on the bench with a vice, hammer hammer tap tap.
  5. Jethro
    Jethro
  6. 55 dude
    55 dude
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    www.jegs.com put this part number in search: 520-11511 $35.99 a pair, sound good?
  8. uglydog56
    uglydog56
  9. river1
    river1
    cone engineering is an Alliance vendor also
    later jim
  10. edweird
    edweird
    thanks for the info,fellas
  11. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Also, there were lots of three tube headers made for Pontiacs. I often see used sets of them at swap meets for cheap; it may be worth your while to pick up a set to cut up for your project.
  12. coneeng
    coneeng
    We have two different styles of 3-1 collectors, a high perormance stacked merge is the most popular, but we also have a flat 3-1 that isn't as high performance but has an awesome vintage look and also can hug in super tight to the motor and frame.
    Look at the bottom of this page: http://www.coneeng.com/collectors.html. And remember if you are an Alliance member you get 5% off.
  13. CrkInsp
    CrkInsp
    from B.A. OK
    Here is are pic of the headers built by the "Senile Ole Men" for there SDRA car.
