Technical Skip The Jack Stands, make Riser Blocks
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Mar 19, 2026.
  1. Marty Strode
    Marty Strode
    A friend and I built these riser blocks. Very safe and handy for building,cleaning and servicing your car. 16” 2X4”s. IMG_6042.jpeg IMG_6044.jpeg IMG_6046.jpeg IMG_6048.jpeg
    badshifter, Koz, 49ratfink and 52 others like this.
  2. Royalshifter
    Royalshifter
    Moderator
    Great safety post.
    I agree, made some a couple years ago and man you feel so much safer under the car.
  3. Thank you, Marty. I have done that for years. Then don't always use them.
    Ben
  4. Sharpone
    Sharpone
    Nice
    How much weight do you think they will handle. OK for a 6500lb truck?
    Dan
  5. twenty8
    twenty8
    Just gluing in 1" wide fillers between each cross piece directly under where the tire sits would greatly increase the load bearing capacity.
  6. Sharpone
    Sharpone
    Da you’re right, my thinker is a little slow today.
    Dan
  7. I made a set out of s**** steel we had laying around, but I need another set and these things are damn heavy. 2 X 4's please.
  8. Marty Strode
    Marty Strode
    I don't know about that, the heaviest I plan on is 3200lbs. But they will sure come in handy for the Top Banana, that's where I got the idea. IMG_1481.jpg
    49ratfink, beegator, treb11 and 21 others like this.
  9. Dave G in Gansevoort
    from Upstate NY
    Next door neighbor is a former contractor. Guess I’ll be raiding his storage sheds for 2x4 s****s…
  10. 325w
    325w
    Cribbing blocks. Very strong . Add some plywood even stronger
  11. Sharpone
    Sharpone
    The Top Banana sure is SWEET.
    Love your top shelf craftsmanship.
    Dan
    Stogy, MMM1693, deathrowdave and 2 others like this.
  12. 51504bat
    51504bat
    Thought about building a set but figured the weight and size when storing them would be an issue. Ended up with 4 of these. They are light and strong. However they were much cheaper when I bought them. But factoring in the price of 2x4's (with the added lumber tax in CA) they might not be all that pricey if you had to buy new lumber. But if you have access to construction cut offs that would be a different story.
    49ratfink, beegator, Stogy and 7 others like this.
  13. 1971BB427
    1971BB427
    from Oregon
    I've made some before, but don't have them anymore. They do take up precious space in my small garage or shop, and I only used them when I wasn't working on wheels, brakes, or times I didn't need the tires off. When you do use them there's nothing better though. Long as yourr shop is not crammed full and you have a corner to stack them in.
  14. alanp561
    alanp561
    If my calculations are correct, that's two 2x4s per stand and you get the additional benefit of that fresh-cut pine smell:). #2 premium studs run around $3.98 around here. Eight bucks a stand, that's a good deal.
  15. cfmvw
    cfmvw
    I've made a few different sets, but my son absconded with them. I did have a pair that I made with a saddle on top that fit the torsion bar housing on VW's.
  16. Do you make them modular, so that you can add or subtract one "insert" to adjust the height?
    Marty Strode, brading and Sharpone like this.
  17. willymakeit
    willymakeit
    Add another row down center with full contact at each level
    Works like cribbing for heavy loads. Don't know what weight capacity is but what i do to all of mine for piece of mind.
    Allows center of tire to have full bearing all the way to the floor.
    49ratfink, Stogy, Squablow and 4 others like this.
  18. I've been thinking about building 4 of them.Thanks for the info guys:)!!
    49ratfink, Stogy and Sharpone like this.
  19. abe lugo
    abe lugo
    I can see using some near 1-1.5' but have seen near 3' high ones and I feel like it's more of a show or hipster thing later more than safety.
    I mean how many barn finds have you seen on these when they are found vs an old car on jackstands? I seen cars on jackstands for decades.
    also they are only as good as how you fasten them together.
    Stay safe guys.
  20. NoSurf
    NoSurf
    Total load divided by 4 (not really). Shear strength perpendicular to the grain times 4 or bending strength times 2.
    alanp561 and Sharpone like this.
  21. Marty Strode
    Marty Strode
    No, Chris has an additional drop in extension that drops in. For now this height works well for me.
    Stogy, alanp561 and Sharpone like this.
  22. Sorry @Marty Strode but I already built several traditional jack stands. :D
    upload_2026-3-20_12-12-20.jpeg upload_2026-3-20_12-12-44.jpeg upload_2026-3-20_12-12-57.jpeg upload_2026-3-20_12-13-15.jpeg
  23. Marty Strode
    Marty Strode
    Rolleiflex, Stogy and Sharpone like this.
  24. jimmy six
    jimmy six
    That’s what I have and use.
    Stogy, Marty Strode and Sharpone like this.
  25. nochop
    nochop
    from norcal
    70001142708__AB67EB08-47B7-4D17-9A9D-21B80CCDDFAA.jpeg That’s the best way to achieve ride height IMG_5547.jpeg
    X-cpe, Deutscher, Okie Pete and 4 others like this.
  26. 51504bat
    51504bat
    Just checked. The 10" high race ramps I have are rated for 1500 pounds each. Plenty good for my '39 p/u and my '54 Ranch Wagon.
    Sharpone likes this.
  27. twenty8
    twenty8
  28. tjm73
    tjm73
    A 2x4 (1.5x3.5) on edge wont crush until about 4500 psi. I'd bet one of these can go beyond 10,000 lbs.
    I put my 2022 F250 4x4 on my cribs with no issues. Mine are just like the OP's.
    Stogy, LWEL9226, AHotRod and 2 others like this.
  29. Sharpone
    Sharpone
    Thanks
    Dan
    Stogy likes this.
  30. Dave G in Gansevoort
    from Upstate NY
    Ooo, I wonder if the neighbor’s wood stock has any 4x4 blocks. Because as a good friend and I always say, a job worth doing is worth over doing!
