Skoty chops built "moneyshot"
Discussion in 'The Hokey Ass Message Board' started by skirtskraper, Apr 12, 2009.
  1. skirtskraper
    skirtskraper
    ID LIKE TO SHARE THESE WITH YOU GUYS, THESE BUILD PICS OF A CAR I BUILT FOR A GUY. THE CAR IS COMPLETED AND GOING FROM BEGINING TO END. HOPE YOU GUYS ENJOY THIS CAR.
    after getting the car down to the body and stripping it of paint you can see i chopped the roof 7"
  2. skirtskraper
    skirtskraper
    in this pic you can see i shortened the body 10"
  3. resqd37Zep
    resqd37Zep
    from Nor Cal
    Very nice work! I hope to see this one in person.
  4. skirtskraper
    skirtskraper
    heres pics of the frame i built for the car.
  5. skirtskraper
    skirtskraper
    here is pics of my patented front suicide perch.
  6. skirtskraper
    skirtskraper
    in this pic you can see that i am clocking all the bolts on this car.
    a pic of the body on the frame[​IMG]
    pinstriping by pinhead on back panel
  7. gr8ness13
    gr8ness13
    I saw this car at Frisco show next to Art's rod it is BAD....!
  8. skirtskraper
    skirtskraper
    heres a pic of the car with the front end ***embled and rearend in, we chose to run a 1952 hemi 331 with a muncie m21 4spd with a full functioning 6 duece set up. also the bueatiful radir tri bars in the rear and the 18" 12 spoke spindles mounts in front.
  9. Coupe-De-CAB
    Coupe-De-CAB
    from Nor Cal
    Skoty,
    It's came out awesome, great job on it brotha!
    Thanks for sharing this on the hamb:)
    cheers,
    cab
  10. skirtskraper
    skirtskraper
    Thank you very much guys, it means alot to me. Im gonna try to finish posting the pics of the build but i may have to finish tomorrow. I got alot of pics to post.
  11. skirtskraper
    skirtskraper
    Steve good talking to you tonight buddy, ill call you tomorrow.
  12. cretin
    cretin
    What do you use to finish fillet welds like this?
  13. skirtskraper
    skirtskraper
    THIS IS A PIC OF THE FLOOR, TUNNEL, PEDALS AND THE SPRINT CAR STEERING BOX.
    HERES A PIC OF THE HEADER THAT IS REINFORCED WITH STEEL INSIDE INSTEAD OF WOOD FOR EXTRA STREGNTH. THE SHEET METAL ON THE HEADER IN THIS PIC IS IN THE PROCESS OF BEING FINISHED.
  14. skirtskraper
    skirtskraper
    HERE YOU CAN SEE THE START OF THE FINISHING ON THE 8 POINT ROLL CAGE I MADE FOR THE CAR.
    HERES A PIC OF THE SKOTY CHOPS FRONT SHOCK MOUNTS
    HERES A PIC OF THE HEADLIGHT BAR STANDS I MADE AND FINISHED THESE IN METAL TO FLOW INTO THE FRAME.
    HERES A PIC FROM THE FRONT OF THE CAR, I KEPT THE LINES OF THE CAR THREW OUT EVERY PART.
  15. skirtskraper
    skirtskraper
    YOU CAN SEE HOW I EXITED THE STEERING BOX IN THIS PIC ON THE COWL.
  16. skirtskraper
    skirtskraper
    WE GOT ALOT OF GREAT STUFF FROM HOTHEADS.COM TO DRESS THE MOTOR.
    HERE YOU CAN SEE MY THROTTLE CABLE MOUNT I MADE.
  17. skirtskraper
    skirtskraper
    I will continue ths tomorrow. Thanks guys!
  18. Looks scary, wouldn't get my *** in it with that pretzel thin frame.
  19. FiddyFour
    FiddyFour
    um... you did this to THAT car?
    yup. nice work
    i think i need to find a new hobby
  20. srosa707
    srosa707
    from Sacramento
  21. Doc.
    Doc.
    Wow! Beautiful work man.
    Doc.
  22. nowaxn5
    nowaxn5
    Incredible work Skoty, looks killer!
  23. skwurl
    skwurl
    Very nice car. You did a great job man.
  24. a.y1320
    a.y1320
    more more more plz......
  25. Definately looks nice from an artistic perspective, but as Doc said.. that frame looks scary. Definately would not p*** over here.
    Here is some CONSTRUCTIVE critisism. As above, i too believe it does look very nice but some things are a worry. Frame only, the Body work looks very well done.
    One thing to watch out for, and is i guess a problem to prospective newcomers looking for pictoral advice as such.. that finishing the welds like that is definately a bad thing. When you grind each fillet weld like that, you are basically removing the outter reinforcement of the weld and greatly reduces the strength of the weld.
    Another point, comes back to the weld finishing but with that Suicide Perch.. if you've finished the welds like that, i wouldn't be surprised if someone could knock those off with a sledge hammer rather easily. Fair enough if their welded underneath (Which we'd all hope..) but the welds should definately have been left unground.
    Looking at a few of your unground welds, i wouldn't see why you would have ground them as they look good as it is.
  26. whid
    whid
    neat car.very nice work......................dave
  27. gnichols
    gnichols
    from Tampa, FL
    I like it... do you have more photos of the cage prior to interior tin? Gary
  28. blackout
    blackout
    I like the Comp Coupe style. The car looks like it is too low to be able to drive it?
  29. Chad s
    Chad s
    I agree, and the ground welds are a BIG mistake.
    Eh... I not a fan of cartoon cars anyway.
