Technical Slant /4 from a V8
Discussion in 'The Hokey Ass Message Board' started by Jalopnik. dr, Aug 15, 2015.
  1. Anyone out there built or have pictures of diy V8 based slant 4's?
    Midget sprint, Drag, or goofy, no factory stuff "(mopar a4, bmw, pontiac trophy 4,)"
    Ps i hope tech is the right place for this?
  2. Kerrynzl
    Kerrynzl
  3. volvobrynk
    volvobrynk
    from Denmark
    This is one cool engine! I like it a lot.
  4. X38
    X38
    They were so common at the speedway for while many moons ago.
  5. coupe man
    coupe man
    Wasn't the early Pontiac tempest 4 cyl.half of a 389 Pontiac engine.
  6. Phil1934
    Phil1934
  7. The37Kid
    The37Kid
    It all started when HISSO V8's got cut in half in the 1920's. Google Half a HISSO for more photos & info. Bob
    Asphalt Demon and volvobrynk like this.
  8. aaggie
    aaggie
    If you think about it almost any V-8 engine could be converted to a V-4 by just removing a few parts and plugging some oil holes.
  9. RichFox
    RichFox
    Joe Fontana makes half Chevy, Ford, and Dodge engines for Midget racers or what ever right now for you. Go to a Midget race and see all kinds of cool bangers. Also, don't forget. Besides Pontiac, International Harvester made a half 392 V8 for the Scout.
  10. PackardV8
    PackardV8
    The approx '69-72 Saab fours were half the Triumph Stag V8, but either version was all junk.
    jack vines
  11. RichFox
    RichFox
    I didn't think of it, but. The Lotus 907 is half of a Lotus something V8. I had a 907 in my roadster for a while. It was a cool motor but not traditional. Maybe Jack will cut a Stude or Packard in half and make a slant 4
  12. Rusty O'Toole
    Rusty O'Toole
    If you want to do this the hard part might be making a 180 degree crankshaft. V8s all use a 90 degree crank which won't fire even in a 4.
    I like the idea of adapting a Chev V8 head onto a Chev 4 cylinder. Or the larger Mercruiser version of the same engine.
    Jalopnik. dr likes this.
  13. Yes there is a lot of cool factory built slant /4's based on V8's this thread is for
    fanken 4's lol grass root style .
    I agree with you Rusty O' Toole the 180* crank wold be the hard part mopar sells the a4 crank but will it fit a half cut V8
  14. Kerrynzl
    Kerrynzl
    The Lotus 907 engine is a Jensen Healey engine.
    It is an aluminium block version of the slant 4 Vauxhall 2000 and 2300 engine found in Bedford vans but with a twin cam head conversion
    The Alloy block Twin Cam version did find its way into Vauxhall Chevette HS2300 for rallying
    volvobrynk likes this.
  15. pdq67
    pdq67
    Learned something from the H.A.M.B. again today!
    Didn't know that IH made 1/2 V-8, 4-bangers!
    Thanks for the info..
    pdq67
  16. Ok this is not the stuff this thread about
    I just read a thread about cutting a car up with axes chisels and hack saws
    So who has built a engine in a similar fashion ok maybe not with an axe or chisel
    Although i here a good sharp estwing wonders on stubborn gaskets lol
    "skin it like a buffalo"
  17. mtkawboy
    mtkawboy
    Rich, how about the small block Monza at Bonneville that runs on one side and has a flathead aluminum head bolted on the other side
  18. Phil1934
    Phil1934
    You don't need a flat crank or custom cam. There are hundreds of Smith air compressors using one V8 bank as engine, the other as compressor.
  19. Rusty O'Toole
    Rusty O'Toole
    They still have 8 pistons to keep balance.
    In the gas crisis seventies some guys converted V8s to 4 cylinders by removing the exhaust valves and the intake valve pushrods. They ran on 4 but still had 8 pistons and rods. Worked ok, with half power. Don't know how much gas they saved.
    volvobrynk and Jalopnik. dr like this.
  20. image.jpg image.jpg Now t
    Here some tools.
  21. If use a V8 crank and remove connrods wont the remaining connrods slide side to side
    Because of exes room
  22. This sound promising
  23. Ya midget guy's did that to but for packaging reasons I'm looking for home built slant /4's
    Im surprised nobody posted a crosley CoBra engine it is closer to what i was looking for then a sesco or a lotus 907 lol
  24. RichFox
    RichFox
    One of Russ Eyres toys. It looks really good from either side, until you take a very good look.
  25. RichFox
    RichFox
    It does have a Vauxhall crank. I don't know what other Vauxhall parts are in there. I have not seen any. But I would not know a Vauxhall part if you were throwing them at me. The 908 would have been the V8 version of the 907. But I guess, beyond prototypes it never went into production
  26. Jakesrocks
    Jakesrocks
    Love that half Hisso. Haven't seen one of those since I was a kid in the 50's.
  27. RichFox
    RichFox
    Engines that I have seen modified in this way, have bob weights clamped to the crank. They take up the space and weight of the missing parts as well as close off the otherwise open oil hole.
    turboroadster likes this.
  28. Kerrynzl
    Kerrynzl
    Vauxhall parts are easy to recognize. They are normally kept outside in a 55 gallon drum waiting for the scrappy to buy them
    moefuzz and Caprice89 like this.
  29. Ya they are beautiful but not really a chopped up v8 since it uses jugs or pots like a vw but dose anyone know how they solved the crankshaft issue?
  30. Kerrynzl
    Kerrynzl
    Here you go,
    Home built slant 4's are very common with modern thin wall 302 Fords
    Easy for the DIYer [ just rev it over 8000 and give it a 250 shot ]
