Technical Slant /4 from a V8
Discussion in 'The Hokey Ass Message Board' started by Jalopnik. dr, Aug 15, 2015.
  1. Oh sorry pork accidentally deleted the the post about .... It wasn't the .........Censuring
    me lol
    :D;)
    No she left the next guy broke and homeless cheating basterd
  2. I just typed flat head four in google and this showed up in images image.jpg
  3. If i used the pontiac id have to drive on the wrong side of the road LMAO
  4. Rich I like you
    That is the best solution i have seen yet much less unobtainium involved then a
    $6000 race only block
    Parts for the pontiac i.e the timing chain tensioner
    Will the poly heads fit on that engine?
  5. RichFox
    RichFox
    I looked at Plymouth 259 Poly heads. To short. DeSoto Hemi heads were perfect. Except for the exhaust pushrod. I gave up on it. But after this LA deal I kind of think I have an idea of how to do it. But, my health keeps me from working on anything these days. So I'm not going to be building ant thing like that.
  6. BnG Engine
    BnG Engine
    Yes Pontiac had the 196 or thereabouts slant 4. Have most of one sitting in the shop. Block, crank, rods, oil pan.
    I always wanted to do one of those V8's that fired 2 cylinders at the same time, but the distributor would be the problem in doing that.
  7. How about the poly 318 i see they are similar to the LA heads
    Do you have a build thread or a page some where with info on your engine build?
  8. As far as i can tell this slant /3 was one of smokey yunicks prototypes from when he was working on when he was working on his hot air engine design image.jpg
    volvobrynk likes this.
  9. With some modern goodies it shouldn't be too hard to get two coils to fire at once
  10. RichFox
    RichFox
    What you need is a modern distributorless ignition. I have run the Electro Motive crank trigger ignition and really like it. It fires two plugs at once. Normally one is wasted like my old Honda 350. Or if you look back a rage you will see a picture of how I fired two plugs at once.
    volvobrynk and Jalopnik. dr like this.
  11. RichFox
    RichFox
    For the Dodge block I had to cut the LA head in half and make a spacer, and get it welded in to put all the chambers over the cylinders. For the Plymouth block the Small block Ford or Y block has 8 of the bolt holes in the correct location and the bore spacing is close enough
  12. Love to see pic of that crank and a pick of the 4cyl rods next to the v8 rods to give a little perspective on how the chief made this mystery mill turn
  13. volvobrynk
    volvobrynk
    from Denmark
    I would love to learn more about this!!
    That's awesome.
    Is there anybody that can answer this: would it be possible to run some of the excess pistons as a piston blower?
    B&W alpha did it on some 4 cylinder blocks for ships, that ran 3 cylindre and a blower. On the crank.
    That should work on a SBC too. And if was possible I bet smokey would have done it at some point.
    He ran a small booster made from a bellhousing of a manual car just filling it up with something, and had the flywheel work an impeller. Weird and plain awesome!
    So if it was done "back in the day", he was the guy to do it.
  14. Here is a patent for a flywheel super charger from what i here smokey never patented his version because when he did a patent search he found that most of his idea was already patented and he was high on the hallucinogenic herb called peyote
    I guess he wrote a cuple of books ,smokey's power secrets, and
    ***, lies and superspeedways
    Here is a patent i found for a fly wheel super charger
    And this is the pic I automatically thought of when I read your post image.jpg
    This photo is from wikipidia
    As for four pistons feeding four pistons exactly the same size i don't think you would build any boost
  15. Ya I know off topic i cant resist a cheat like smokey
  16. Rusty O'Toole
    Rusty O'Toole
    Franklin had a flywheel blower in 1904 but they used it to air cool the engine. In their ads they said "the only moving part in the cooling system is the flywheel, and as every engine must have a flywheel to run, it is evident that the limit of simplicity has been reached".
    Jalopnik. dr and volvobrynk like this.
  17. RichFox
    RichFox
    I bought a new 4 cylinder Pontiac Tempst in '63. The crank was a normal flat four cylinder with counterweights. The rods and pistons were standard 389 Pontiac pieces. Used one 389 head. Even the distributor was based on the V8. Every other plug wire post was a flat blank. It was a good little engine except for the timing chain. Due to the less frequent power pulses the chain needed extra guides. Which broke off and fell into the bottom and allowed a very loose timing chain. I started changing mine at 10,000 miles.
    Jalopnik. dr likes this.
  18. falcongeorge
    falcongeorge
    from BC
    only thing is, they usually split horizontally...
  19. Do you think a gear driven cam would have worked better like the ihc scout 4cyl and truck v8's
    My guess would be to go with a gear with only two gears like the ihc i would have to get a cam with a reversed cam profile?
  20. RichFox
    RichFox
    That is true. A gear drive that turns correctly is not hard to buy or build. You can use a second crank gear that would have driven the chain, as am idler gear. You would need to make the mount and adapt the gear to use bearings. But that was how people got gear drives before you could buy them
  21. Rusty O'Toole
    Rusty O'Toole
    Do a search for "Smokey Yunick adiabatic engine" or "hot vapor engine". He did a lot of work on this in the 80s and had a couple of prototypes running on the roads. Auto company engineers the world over were looking at it. It almost reached production, the drawback was the engine ran at the very limit of overheating, if anything went wrong the engine would burn up in an eye blink.
    http://schou.dk/hvce/
  22. wha?? I would to see that. Are they using the dead side for anything, compressor etc?
  23. BnG Engine
    BnG Engine
    Ok here are some pictures of before I had it cleaned. In the one picture you can see the crankshaft standing up in the background next to the pistons in the oil pan. It's covered with dust from the gl*** beader.
    285456_255175957844381_1989330_n.jpg 284741_255175704511073_1372144_n.jpg 282436_255176027844374_1178838_n.jpg 281266_255175761177734_4865335_n.jpg 252156_255175637844413_3000423_n.jpg 250366_255175894511054_148908_n.jpg 198696_255175821177728_7113815_n.jpg
  24. volvobrynk
    volvobrynk
    from Denmark
    I know of the hot vapor fiero, I know of it from the www and smokey autobiography. And I liked it.
    But it ain't a half V8, it's a 4 banger. I know 4 is half of 8 but not like it's a V8 block.
    But I referred to the V8 with a block of plate instead of the one head. Go a couple pages back.
  25. BnG Engine
    BnG Engine
    I believe Pontiac did this with the 389 to test out the feasibility of making their slant 4.
  26. I believe it started life as a v6 but what ever
  27. Do you still have the counter weights?
  28. JeffB2
    JeffB2
    from Phoenix,AZ
    The kit to do that was made by Crower Cams.
  29. Thanks for your post i started looking a little closer a Saab because of it i forgot what you said in tell I read it again thanks again
  30. So the saab engine because it was an engine derived from a british engine leans to the left
    Thats ware the ether half of all those pontiac and ihc v8s went
    The kids clam 500 hp stock internals just dialling up the boot and fuel
    Im seeing hole running turbo 9000 saab for less the a thousand
