Slant 6 and HA/GR ?
Discussion in 'The Hokey Ass Message Board' started by flynj1, Dec 25, 2005.
  1. flynj1
    flynj1
    from C.B. IOWA
    We are trying to start a new HA/GR team and I ask this on another thread but dont have an answer. We ar leaning to running a slant 6 and would like to make shure its leagle to run one. Both 170 and 225 were in production pre 62. Now do we have to run a block with #s pre 62 os or can we run say a 1968 225 since they are the same as pre 62s. Thanks
  2. Rand Man
    Rand Man
    Better PM Ryan on that one.
  3. flynj1
    flynj1
    from C.B. IOWA
  4. Animal
    Animal
    pm'ed ya
  5. If there is an answer, please put it up on the main board... inquiring minds wanna know!;) :D
    PS, early models were aluminum blocks, (spam) I'm trying to find one... (spam).
    Jay
  6. flynj1
    flynj1
    from C.B. IOWA
    Yea we are looking for one of the early alum. blocks as well but we will run what we can find CHEEP.
  7. peanut
    peanut
    yea i would like to know. before 62? or 62 and before? and how about if you ran an A engine could you get something extra? or maybe run two As?
  8. peanut
    peanut
    give us some more info ryan!
  9. ElPlymino
    ElPlymino
    from Orcutt
  10. gettingreasy
    gettingreasy
    So what does HA/GR stand for?
  11. flynj1
    flynj1
    from C.B. IOWA
    H.A.M.B. Gas Rail
  12. Derek Mitchell
    Derek Mitchell
    Just my $.02, but it should be a casting # before '62. Just because they made it before doesn't mean they didn't make changes to the design and function of the motor.
  13. REJ
    REJ
    from FLA
    The slant motor was in production in 1960, and it was not an aluminum block. Chrysler only made about 50,000 of these before they went to the cast iron blocks. The aluminum blocks are not really good for racing applications as they were prone to not sealing to the head and porosity was still a problem.
    The 225 and the 170 are the same blocks, the only difference was the stroke of the motor. 225 is a long stroke motor and the 170 is one inch shorter on the stroke.
    As far as any changes to the motor, none except to the heads and they changed to hyd cams in the late 70's. They also changed from a steel crank to a cast crank with the hyd. motors.
  14. come on....sam....ryan...anyone? i'd like to know this as well...
  15. 53sled
    53sled
    from KCMO
    there is an aluminum one on the bay right know, its in the carolinas.
  16. bob hindman
    bob hindman
  17. Ryan
    Ryan
    ADMINISTRATOR
    Sorry fellas... I completely missed this.
    I hate talking about rules.
    We are allowing but discouraging people from running blocks with later than 62 numbers, but same design as pre-62 blocks. Reasoning? I can't begin to even pretend that I know much of anything about these odd ball motors. If you run a '64 block and it turns out there is a serious performance advantage over a pre-'62 block then we will have ta call you names, punt your cat, and sleep with your sister.... sorry... **** happens... You will also be disqualified.
    So be safe - go out and find a pre-62 block... Your sister will thank you later.
    And if we change the rules next year, you won't be all pissed off when ya can't run against your buddies with thier cool pre-62 ****...
  18. Ryan
    Ryan
    ADMINISTRATOR
    Another thought... I have no idea how this HA/GR thing is going to play out, but I wouldn't be surprised if we ended up splitting the cl*** into two groups: flatheads and overheads.
    I think the flathead cars are the coolest to look at, the most fun to hear, and well... I just really like them... So I don't want folks to steer away from flatheads because they might be behind the overheads a tad... I think they could end up being the most fun...
  19. REJ
    REJ
    from FLA
    I like the sound of this!
    Not that I have anything against the flatheads, I have never built one and would not know where to start. Now the slants, I have been into them for 8 years.
    I really think this is the way to go, overheads against overheads and flatheads against flatheads, eights and sixes.
  20. 53sled
    53sled
    from KCMO
    Mopar or NO CAR!
    id still like to run my 235, just cause I like chevs
  21. REJ
    REJ
    from FLA
    Run the Chevy! I would love to see several different motors on these things.
    In fact, I know it would not fit the cl***, but I thought about running a double engine dragster.:D
  22. flynj1
    flynj1
    from C.B. IOWA
    we could run the 235 in the second car
  23. 53sled
    53sled
    from KCMO
    awesome. i'll see what parts are in the shed, maybe i'll talk him out of the built motor, take off the 4bbl, run it!
  24. flynj1
    flynj1
    from C.B. IOWA
    Works for me.
  25. 53sled
    53sled
    from KCMO
    here is a link to the specs for slant sixes. 68-newer looks to be the cutoff, according to the rules, as 67-older are all pretty much the same, beter cranks too!
    http://www.slantsix.org/articles/parts-matrix/jpg.htm
    shows a 4 bbl for 60-62 225 as optional factory equipment.:eek:
  26. REJ,
    "The 225 and the 170 are the same blocks, the only difference was the stroke of the motor. 225 is a long stroke motor and the 170 is one inch shorter on the stroke."
    Gotta call ya on that one. I think the BORE is the same, but the block is shorter. Hence why the 225 is an "RG" and a 170 is a "G".:rolleyes:
    But that's nitpicky... BRING ON THE SLANTS!!!!
    And, since they were intro'd in 1960, would a "Hyper Pak" be a legal combo?
    PS, avoid anything post 74 (maybe was 76)... they went to cast cranks. And post 84 were hydralic lifters, YUK!!!:p
    Jay
  27. REJ
    REJ
    from FLA
    Sixgunner, the blocks are the same length, but they are shorter on deck height, therefore the 170 has a one inch shorter stroke. If they were the same height, the 170 would probably be a 4-1 compression ratio with the piston that far down in the hole.
    All pre-68 blocks are the same, steel cranks and the block was cast a little bit thicker. After that they went to cast cranks, lightened the block up a little bit, went to hyd cam in the late 70's early 80's. The late model heads have a little bit better combustion chamber than the early ones.
  28. REJ
    REJ
    from FLA
    Speaking of the hyper pak manifold, read the rules, no four barrels.:(
  29. Jim Marlett
    Jim Marlett
    Actually, the rules don't say no 4bbls. They say "Era specific carbs only, stock appearing- no modern Holley,Edelbrock, or other aftermarket carbs." Perhaps guidance on what "Era specific" means would be useful, but one of the first three HA/GRs runs an early Ford/Holley 4bbl.
  30. Ryan
    Ryan
    ADMINISTRATOR
    The 4-barrel rule will most likely be added...
    Man... those slant 6's are ****ing ugly. We might outlaw em just cuz of that! :)
