Technical Slant 6 w/3 speed problem...any ideas?
Discussion in 'The Hokey Ass Message Board' started by poboyross, May 29, 2017.
  1. poboyross
    poboyross
    from West TN
    I'm looking at a local H.A.M.B. friendly car that has a 225 w/3 on the tree. The owner claims that it has a new clutch, but when giving it gas in 1st, it starts making this clanking noise that sounds like pressure building and being released, if that makes any sense. It increases based on speed, but goes away in 2nd or 3rd. It is also present in Reverse. Any ideas?
  2. Hnstray
    Hnstray
    from Quincy, IL
    Bad 1st & reverse slider gear .....tooth/teeth missing? Bad bearings in cluster gear/shaft? Possibly bad bearings in input gear to main shaft junction?
    Maybe, but not as likely I think, bad u-joint(s).
    Needs ****** work from the sound of it..
    Ray
  3. poboyross
    poboyross
    from West TN
    ***uming it's ****** work (which isn't my forte), does that type of work take bank nowadays?
  4. Hnstray
    Hnstray
    from Quincy, IL
    Depends on a number of factors. Can you source a used ****** at a reasonable price? Do you have any car guy friends competent and willing to work on your transmission? Do you have skills and tools to remove and reinstall the transmission if you find another or someone to rebuild yours? My guess is a professional shop rebuild would be pretty pricey in the LA market.
    Ray
    poboyross likes this.
