Technical Slant pan hydro question
Discussion in 'The Hokey Ass Message Board' started by Groucho, Aug 6, 2020.
  1. Does it have a vacuum modulator? Thx
  2. Dave Downs
    Dave Downs
    from S.E. Penna
    I don’t think any of the ‘Hydro’s’ had a vacuum modulator
  3. BJR
    BJR
    No, used linkage up to the carb, with a funky bracket with a spring and bell crank. This worked p***ing gear and I believe the up shifts.
  4. Rckt98
    Rckt98
    What BJR said but it is critical this is adjusted correctly. Definitely no vacuum modulator.
  5. Yeah, I need to get a link to adjust. It hangs in 2nd until I let off the gas.
  6. Contact Fastgo transmissions in New Jersey, or cl***ichydramatic.com. they specialize in hydramatic transmissions.
  7. Elcohaulic
    Elcohaulic
    TV rod goes to the carb and senses the throttle position. This is very important to have connected and adjusted correctly. Disconnect the cup from the ball at the carb. You should have to pull it about a 1/4 of an inch to get it to snap on if adjusted correctly...
  9. warbird1
    warbird1
    What engine/Hydro combination are you using? That would determine how to adjust the throttle valve linkage...
