Slapping file question
Discussion in 'The Hokey Ass Message Board' started by camcb, Oct 6, 2013.
  1. camcb
    camcb
    Do you guys use them and if so where do you buy one ?
  2. 1/2done
    1/2done
    from Ohio
    You're better off with a smooth surface, I made mine from an old leaf spring.
  3. vega1
    vega1
    Slap file for raising and shrinking got mine from Martin
  4. fleet-master
    fleet-master
    i made my own, heated and bent a few up from cross cut files with different sizes and shapes.
  5. sdrodder
    sdrodder
    from Houston TX
    make your own. Get a good crosscut file, cut it in half or the desired lenght. Then weld on a thicker screwdriver where the shaft has been bent.
  6. Rehpotsirhcj
    Rehpotsirhcj
    X2. I made mine from a short leaf. I have a couple, but that one is my most used. I like having a little weight behind the *******. Less work, no hammer marks.
  7. jw johnston
    jw johnston
    X3 on the ******* made with a leaf spring but not completely smooth. I like to run the contact face on a belt sander with 80 grit long ways. The scratches aren't rough enough to mark the sheet metal but mark it enough to help with tracking so you can see where you are hitting easier.
  8. camcb
    camcb
    Thanks guys!
  9. TR Waters
    TR Waters
    from Vermont
    A slapping file is completely different than a slapping s****.
  10. chopolds
    chopolds
    from howell, nj
    I use both smooth and the file type. For a beginner, it is much easier to use the file type, as you can see your progress very clearly. It also seems to work faster.
    You can get file types from Eastwood, and I see them on Ebay all the time. The smooth *******, you can get from Tinman Tech, Dagger Tool, and others, or make your own, as others suggest.
  11. camcb
    camcb
    I'm going to make my first one out of a large cross cut file and later make a smooth one out of a leaf spring. I tried using the large file I have with a dolly as an experiment on my 48 Plymouth and was thrilled with the results on one bad dent below the back window. If you have not tried this method give a shot as it's cool.
