Technical Slave cylinder
Discussion in 'The Hokey Ass Message Board' started by johnfin, Nov 22, 2025.
  1. johnfin
    johnfin
    from Florida
    AI says these cars have a slave cylinder. I believe its full of bs. I have one on my rod and was watching a video on bleeding the clutch system and it said to block off the slave with a clamp. I was wondering if thats to get the air out of the master.
    bobss396 likes this.
  2. manyolcars
    manyolcars
    What are you talking about? All hydraulic systems have a master and slave cylinders
  3. johnfin
    johnfin
    from Florida
    I am saying that old muscle cars dont have hydraulic clutches like AI says. They use a Zbar.
  4. RodStRace
    RodStRace
    SS327 likes this.
  5. 19Eddy30
    19Eddy30
    from VA
    Ai probably 60% wrong ..,
    Yes & No on clamp on hose to a certain
    Extent , air will rise if cap left off ,
    50/50 that all air will escape.
    Some time's it like changing a brake line
    Gravity letting brake fluid drip from
    Higher up from reservoir with top off, & other line still full of fluid
    To top of fitting .
    You can attach fitting there will be no air. Self bleed @ connection.
    If all new crack bleeder , let gravity feed
    Then bleed like a brake master cylinder.
    I have heard of Z bar , I call it clutch Fork & rod or cable
  6. RodStRace
    RodStRace
    Z bar top left, clutch fork top right
    SS327 and Just Gary like this.
  7. 19Eddy30
    19Eddy30
    from VA
    Z bar part off frame to block , me Da !
    RodStRace likes this.
  8. johnfin
    johnfin
    from Florida
    The video showed the clamp pushing the slave piston in while bleeding, not the hose.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
  10. johnfin
    johnfin
    from Florida
  11. bobss396
    bobss396
    I have a few deeds left to the Brooklyn Bridge. Let me know if you are interested .
  12. winduptoy
    winduptoy
    ....does the clevis pin need a cotter key to start the car....
    ....do windows wind a different direction in Australia....
    ....why do they call them shock absorbers....they didn't work when I grabbed spark plug wire......
    SS327, Just Gary and RodStRace like this.
  13. johnfin
    johnfin
    from Florida
    I wanted your thoughts on compressing the slave while bleeding. Not a bunch of riddles.
  14. squirrel
    then why did you mention ai?
    sheesh.
    Just ask the question you want the answer to.
    Yes, that was probably to bleed the master cylinder.
  15. 19Eddy30
    19Eddy30
    from VA
    Do not know witch style you have
    I would say when you push clutch peddle down the Save extend , if so
    Crack bleeder then use a C clamp or wide jaw Vice grips , to collapse rod ,
    Or unbolt push back with fingers ,
    So no air pocket on piston , completely collapsed With bleeder open should gravity bleed.
    You can do same bleed method on disc calipers by completely compressing the piston up into the caliper, then just let gravity bleed,wants done pump brake slow
    Top off Master cylinder.
    Wheel cylinder also.
  16. goldmountain
    goldmountain
    Unbolt the slave cylinder from the car but with the hydraulic hose hooked up. Hold it in position so that the piston can be pushed with a screwdriver or something upwards. Push it in and the air will escape upward into the master cylinder. No helper needed.
    19Eddy30 likes this.
  17. Jack E/NJ
    Jack E/NJ
    from NJ
    > I wanted your thoughts > Not a bunch of riddles. >
    I think you should take it to Meineke and let them handle it.
