Projects Sliding window locks for '55 Ford Ranch Wagon
Discussion in 'The Hokey Ass Message Board' started by MarcosA, Dec 18, 2024.
  1. MarcosA
    MarcosA
    Hello all, I was wondering where I can possibly find the locks for the right and left (on the window and on the body). For a 1955 Ford Ranch Wagon. Or anyone have a part number
  2. bobss396 likes this.
  3. badshifter
    badshifter
    It’s been a minute, but I may have some. But, with Christmas a few days away I can’t dig through my stash for a week or two. Same latch as the country sedan. Been there, did this…
  4. MarcosA
    MarcosA
    Hi Badshifter,
    Sweet ride for sure! I understand and if you don't mind looking afterwards I'm OK with that. Just please keep me posted. Merry Christmas
  5. 325w
    325w
    A form of the lock is a reproduction for tri five nomads. Nomads use a lock for the sliding gl***. Might work.
  6. MarcosA
    MarcosA
    I'm really not sure what repoped. I'm sorry
  7. In_The_Pink
    In_The_Pink
  8. okiedokie
    okiedokie
    from Ok
    Norbert Doll in Glencoe Ok is Worth a try if nothing shows up. True gentleman deals in mid fifties Ford stuff.
  9. HOTRODPRIMER
    HOTRODPRIMER
    This is the lock for the sliding window that I dis***embled to have them rechromed, you use gl*** tape and drive the latch on with a rubber mallet.
    This shows you the position of the latch.
    This photo was taken when we were installing the interior, the latch is in place and you can see the attachment half way up on the B pillar.
    Hope this helps. HRP
    dana barlow, J_J_ and miker98038 like this.
  10. Louis Rankin
    Louis Rankin
    Did you ever find a suitable latch or subs***ute?
  11. MarcosA
    MarcosA
    No I have not found the parts yet
  12. It's been a loooong time since I owned one, but as I recall the '55 through '59 two door wagons used a U-shaped chrome channel roughly 2" x 4" that glued to the gl***. This had an inside handle similar to the vent window handles but larger with a hook that engaged into the square hole in the window escutcheon. The hole should have a die-cast chrome trim around it riveted on to accept the hook. There should also be a wide spot in the window channel to allow the latch channel to fit. These are all the same basic latch but there may be some variation in the handle design to mimic whatever style vent window latch was used that year. These will be found on all '55-59 Ford 2 door wagons, but you'll also find them on the 8/9 p***enger wagons for the third seat windows. '55-56 Mercury in the same body styles will have them also, but not the later ones as Mercury diverged from Ford '57 through '60.
    The latches shown in post 9 are '52-54 only and won't fit. But these are about the same size looking from outside as the correct ones.
  13. 51504bat
    51504bat
    I know that this is an old post but the Ford Part Number is BA-5929668-A One on the auction site right now if you're still looking
  14. pprather
    pprather
    @51504bat can you provide a link to the window latch?
    Thanks.
  15. 51504bat
    51504bat
  16. pprather
    pprather
    Thanks.
    Those are 1952-1954.
    OP needs 1955-1959 style.
    Thanks for helping.
    51504bat likes this.
  17. 51504bat
    51504bat
    My mistake. I'll check for the correct part number when I go to the shop later today.
  18. 51504bat
    51504bat
    1955/1956 latch numbers are:
    Right hand: B5A-5929668-B
    Left hand: B5A-5929669-B
    pprather likes this.
