Slow progress: Sheetmetal work is harder than it looks...
Discussion in 'The Hokey Ass Message Board' started by Deuce Rails, Jul 21, 2004.
  1. Deuce Rails
    Deuce Rails
    I have a lot of irons in the fire, so to speak, but my major love is my 1932 Ford racer. If you're not familiar with this project, it's a 32 Ford with a home-made body, that's trying hard to look 1930's exotic.
    I finally got the body buck built (a while ago), and found a sensible way to anneal the aluminum sheet that makes up the body itself.
    After a LOT of hammering and fitting, I have a fraction of the rear boattail done.
    I have to say that building bodywork from scratch isn't as easy as it may sound...
    --Matt
  2. Matt...I really like boat tails!! What is the rest of the body going to be like? Stock looking frontend with the boat tail on the back? Fendered or fenderless?
    Clark
  3. 34Fordtk
    34Fordtk
    Yeah man I like that!! More pics please.
  4. SimonSez
    SimonSez
    Hope you're putting that Ardun valve cover on the right sort of head [​IMG]
  5. Unkl Ian
    Unkl Ian
    The guys on the Metalshapers site would be interested in your progress.
    metalshapers.org
  6. The37Kid
    The37Kid
    Rails, Got to give you some encouragement. This is the Don Lee Special, took the photo at the Road Agents meet on Saturday.
  7. Deuce Rails
    Deuce Rails
    Thanks for the kind words, guys.
    Clark, the car will be either fenderless or have small cycle fenders. The hood will be longer than stock.
    Bruce Lancaster and I discussed this a long time ago at Carlisle. He recommended that I retain the stock firewall because it's a structural piece. So I decided to extend the hood rearward past the firewall, with a supporting cowl under the hood, and a small cowl that's visible with the hood closed. (By the way, the angles involved mean that the rear would get faily wide at the rear if I don't widen the grille shell...)
    Here's my photoshop rendering:
  8. Deuce Rails
    Deuce Rails
    While I'm at it, here's the buck (and my thumb!):
  9. Deuce Rails
    Deuce Rails
    And how I laid it out with aluminum welding rod.
  10. Deuce Rails
    Deuce Rails
    Finally...
    Simon, there is indeed a flathead in it. Unfortunately, the Ardun heads are the plastic fakes that I got from eBay. I primered them with Fusion paint and coated them with Alumablast. They'll be decent as wall art.
    And thanks, Unkl. I will post this on the Metalshapers site.
    --Matt
  11. stealthcruiser
    stealthcruiser
    so,tell us how you got those big sheets annealed,
    at the header coating place?
    us nosey *******s wanna' know!
    thanks
  12. "harder than it looks"?!
    I don't know about anyone else, but to me it looks damn hard right off the hop. It also looks like you're doing a great job, keep going, and keep us posted. [​IMG]
  13. Elmo Rodge
    Elmo Rodge
    [ QUOTE ]
    [/ QUOTE ]
    What are Fusion paint and Alumablast? Wayno
  14. Deuce Rails
    Deuce Rails
    Chuck, I took the sheets to a heat treating facility and they did a bunch of them in between real, paying, military contract work.
    Thanks a lot, Big A.
    Wayno, Fusion is a rattle can primer sold by Krylon that's intended for plastic. Alumablast is a silver spray paint that has a high aluminum content.
  15. praisethelowered
    praisethelowered
    Wow, what a project. That will defintely be worth all the work in the end.
  16. Gotta love boat tail speedsters!
    I have always wanted to build a Model A boat tail... ever since seeing them at Model A "roundups" as a kid.
    DuecheRails, I'm sure you already have... but if you haven't, check out the Great Race's web site. There were wuite a few boat tail's with '32 frames that roared through Pleasanton a few weeks ago. Real neat stuff.
    Sam.
  17. Kevin Lee
    Kevin Lee
    Super Moderator
    A local guy builds these Modal A speedsters - never met him though. Yours looks right - and if you've been brainstorming with Bruce L. I'm sure you've ended up with tons of cool ideas. Good luck and keep us posted.
  18. mule
    mule
    If you are using commercial grade aluminium, you can anneal it by using your oxy welder with out oxy turned on to leave a black film on the alli. Once you have covered the panel in black, set your flame with the oxy to a blue flame, carefully burn the black off without over heating the metal and it will be like working with rubber, you will then need to heat treat the metal back to it,s og properties. Practise on a bit of s**** first.
  19. Deuce Rails
    Deuce Rails
    [ QUOTE ]
    [/ QUOTE ]
    Lord, I hope so! [​IMG]
  20. Hay Kev- is that Joey E. or some one else?
  21. Deuce Rails
    Deuce Rails
    Grimlok,
    Who is that guy? He does nice work.
    The flat Model A frame is a LOT easier to work on...
  22. bettyvixin
    bettyvixin
    It is def harder then it sounds!.. Stick with it, and make sure u keep us updated with the pics.. It will be worth it.
    Best of Luck
  23. Keep hammer'n' away. Boat tails are just too cool. Always have been. Auburn boat tail ummmmmmmm
  24. Kevin Lee
    Kevin Lee
    Super Moderator
    Is Joey E. the axle dropping guy with the blue modified?...it isn't him. I forgot this guy's name - but KCTAchris knows him so you might contact him if you want info.
  25. Petejoe
    Petejoe
    from Zoar, Ohio
    Cool work! Patience is the key with that much metalwork.
    [ QUOTE ]
    [/ QUOTE ]
    Didn't know this. Exactly why this place is so great!
  26. Deuce Rails
    Deuce Rails
    Annealing this big of a sheet is more difficult than Mule makes it sound.
    I can use that method with no problem on smaller sheets of aluminum, but for a piece as big as I'm using, I just can't keep the heat consistant.
    For what it's worth, here's the expert explanation of how the soot method works:
    http://www.metalshapers.org/tips/covell/annealing.shtml
    So far, my sheetmetal is fitting within 3/8" of the buck. I want to get it to 1/4". That extra eighth is killing me!
    Here's my rear-end view, rendered in PhotoShop. Imagine it with cycle fenders.
    --Matt
  27. SanDiegoJoe
    SanDiegoJoe
    [ QUOTE ]
    --Matt
    [/ QUOTE ]
    Looks spooky.
