Technical Small Alternator
Discussion in 'Traditional Hot Rods' started by Ron Plumlee, Aug 23, 2016.
  1. Ron Plumlee
    Ron Plumlee
    See lots of great info on subject, maybe some of you can help: running 8BA with 59A pumps, Bubba dizzy, and 97s. GM alternator is 5-1/2" deep X 5-1/2" diameter....about an inch two large both directions, esp in depth, it hits the front carb. Who makes a smaller alt, around 4-1/2" deep and 4-1/2" diam?? Raising the carbs no go, no hood clearance, and really want to keep alt centered, not offset. Also, no go on later pumps, no space. Help!
    Mopar Alt???
  2. 325w
    325w
    Nepondenzo (sp) but low out put.
    porknbeaner likes this.
  3. Phil1934
    Phil1934
  4. Mr48chev
  5. DDDenny
    Kubota tractor.
    LOU WELLS and da34guy like this.
  6. LOU WELLS
    LOU WELLS
    from IDAHO
    Kubota 62 amp/hot wire and one wire to excite $160.00 from parts store or $60.00 new on E-bay.... ODD ENDS 2016 006.JPG
  7. hotroddon
    hotroddon
    I've used Suzuki Samurai 50A output
    Here is one next to a typical GM
    LOU WELLS likes this.
  8. Yep^^^^^ and you can get these little guys that make mega amps too.
  9. dirt t
    dirt t
    I used that samurai alt also. Can be made 1 Wire also.
  10. Marty Strode
    Marty Strode
    I use a Denso 35 amp unit. This is an 8BA with early pumps. IMG_0561.JPG IMG_0679.JPG
  11. nmpontiac
    nmpontiac
    from Taos, NM
  12. hotrodA
    hotrodA
  13. I use a Kubota 55A on my Avatar/, Evans Triple, custom pulley/fan mount. No clearance issues.
  14. mustangsix
    mustangsix
    There are some really stupid-small (3" diameter) permanent magnet lawn tractor alternators that could work. The output is low, only 14-15A, but if you don't have monster headlights, air, and a 10,000 watt amplifier, they could work. There's a similar one for a John Deere that puts out 20A.
  15. touring20
    touring20
    Installing one of these on a Chevy 327 , but the pulley looks to wide (1/2").
    The stock pulley on the Chevy is 3/8" . Some refer to the pulley that comes with the mini alt is a universal pulley , any one run this configuration ? Does it work ?
  16. 27TV8
    27TV8
    Here is a Kabota I put in a 28 Powerhouse. Have it finished now and it runs great,not much amps but I don,t need much
