Small batteries, what to use?
Discussion in 'The Hokey Ass Message Board' started by oj, Oct 10, 2012.
  1. oj
    oj
    Due to a very small space i can't use a conventional battery on my modified. I am thinking about a pair of those 6v optima - behind the cab, under the gas tank, one battery on either side of the driveshaft.
    Any other suggestion?
  2. wingman9
    wingman9
    from left coast
    How about an Odyssey PC680? 7 1/8" x 3" x 6 5/8"
  3. Look at Odyssey batteries.
    Made by enersys
    They pack alot of amps in them rascals
  4. Endless Mike
    Endless Mike
  5. DoubleJ52
    DoubleJ52
    from Belton, MO
    X3 on the Odyessy's.
  6. GARY T.
    GARY T.
    from S.W. Pa
    Isn't that a motorcycle battery? Would it be OK in a car? Any drawbacks with using one?---I LOVE the size of it
  7. oj
    oj
    Do you have experience with it? Need special charger? How about a trickle chrger/battery minder, will they work?
    These are very light and can be mounted in any fashion, right?
    Thanks, oj
  8. Braille Model B3121 specs:
    Volts - 12 Volt
    Battery Terminals - Top and side
    Battery Type - AGM
    Cranking Amps at 0 Degrees F - 550 amps
    Cranking Amps at 32 Degrees F - 742 amps
    Reserve Capacity - 75 minutes
    Length (in) - 6.600 in.
    Width (in) - 5.200 in.
    Height (in) - 6.800 in.
    Weight - 21.000 lbs
  9. Jimmy2car
    Jimmy2car
    from No. Cal
    Get the Odyssey.
    I've got one in my 32 Tudor under the rear seat. It works GREAT. No special chargers needed, can mount in any position except upside down. Cranks my big flattie just fine.
    BTW, weighs about 11 lbs.
  10. striper
    striper
    I use one of these OJ. Cranks the 401 no problem. I use a standard trickle charger on it. I think the manufacturer would like you to buy their charger but mine is 3+ years old and still going strong. Mine is mounted on its side up under the dash on a swing down panel. Mount them any way but upside down I believe.
    Pete
  11. Von MoPar
    Von MoPar
    from Australia
    good info, thanks.
  12. LongT
    LongT
    I have an Odyssey 925 in my T. A bit pricey at $194, I believe, but its been in there 6 years and still works great. I've parked out side at 7 degrees for over an hour and not noticed any change in cranking. Typical 355 Chev in a T-bucket.
    BIll
  13. dubcee
    dubcee
    I run the Odyssey 925 in my A crankin over a dual quad 389 with no problems what so ever! You can find them on line around $130, pretty simmilar to the price of a big ol optima!
  14. Turbo26T
    Turbo26T
    I bought an Odyssey PC925 six years ago...Kept stored on a float-charge type Battery Tender until last Nov '11...Finally put in in the roadster and it cranks just fine ..car sits weeks at a time ,cranks every time. They are kinda pricey now ( What ain't??) but, Battery Mart has about the best price and free shipping http://www.batterymart.com/p-odyssey-pc925L-battery.html
    You can mount it any way ,except upside down, Mine has the metal jacket. They can be ordered with the terminals reversed if you need it
  15. Wildfire
    Wildfire
    2X for Miata batteries - cheap and small. But those others are super nice and so small you can put them anywhere
  16. CruZer
    CruZer
    Look at Performance Distributors "Dynabatt" . I have had three of them in two rods over the years and they work fine and last at least 5years. One of mine lasted 8 .I think it's the same as the other solid state small batteries.
    The one in my roadster fits right inside the rear fender well.
  17. unkledaddy
    unkledaddy
    ^^^"Dynabatt" is just a re-labeled Odyssey for more $$.^^^
  18. radgirl
    radgirl
  19. steel rebel
    steel rebel
    When I put a larger fuel tank in the P.U. bed of my roadster I needed a smaller battery. I went down to Wallmart and got the smallest one they had. I think it's for a Honda. About $60 and if you don't have a real high compression engine it works fine and if and when it goes bad there is a replacement around the corner.
  20. It's not "if" but when it goes bad. There's a good reason why they're called a WalMart Neverstart! ;)
  21. steel rebel
    steel rebel
    And $200-$300 batteries last forever? I've never had a Wallmart battery last less than it's warranty.
  22. wingman9
    wingman9
    from left coast
    It cranks a 377" 10:1cr sbc just fine. I have a Battery Tender for it but I've never needed to charge it. The car sits for a month sometimes and the battery still has enough charge to do it's thing. The battery weighs about 15 lbs and can be mounted in any position except upside down.
  23. gearheadbill
    gearheadbill
    Agree. I am using one in my SBC powered tub and it works great. I don't know that it has the reserve power to grind and grind on the starter but if everything else is working properly it is fine.
  24. Perhaps things are different out by you. I didn't come up with the Neverstart name, it's well known out by me. I learned the hard way, I replaced 3 Neverstarts in 1 summer. The O/T vehicle had no electrical issues, it just needed a battery. I put an Interstate in it and problem solved. On the flip side, WalMart did replace all 3 batteries, no questions asked. I guess they know as well. ;)
  25. bobscogin
    bobscogin
    Yup, same experience here. I'm a firm believer in Odyssey batteries.
    Bob
