Projects Small bead rubber trim
Discussion in 'The Hokey Ass Message Board' started by Tom Noller, Dec 7, 2015.
  1. Tom Noller
    Tom Noller
    from Iowa
    Greetings Guys, Working on my project and hope to use a small piece of 18 gauge sheet metal as a dash insert for newer gauges and would like to find some rubber trim to seat along the edge. More for a finished look, once I paint the piece and slide it into place. Any*******mendations for a source? Thanks!
  2. You can use a rubber /plastic tube slit length wise and press it onto and along the edge of the sheet metal....
    Could also use brake/gas line if you had a way to make the straight length wise cut???
  3. 325w
    325w
    Maybe door edge guard that's my only*******mendations!
  4. Tom Noller
    Tom Noller
    from Iowa
    Good ideas, thank you!
  5. Donald A. Smith
    Donald A. Smith
    from Brook In.
    Small vacum hose that you would use on a 57 chevy distributor . Get it at NAPA Don in Indiana
  6. Texas Webb
    Texas Webb
    Tom,check auto upholstery shops/suppliers.They have small vinyl tube already split with adhesive inside that you can cut to length.
  7. nmpontiac
    nmpontiac
    from Taos, NM
    most of the early car places sell fender welt - not sure if it's small enough for what you want.
  8. McMaster-Carr, search for 'rubber edge trim'..... lots of choices.
    RICH B and 30TudorSedan like this.
  9. blue 49
    blue 49
    from Iowa
    Small airplane parts suppliers like Aircraft Spruce.
  10. stanlow69
    stanlow69
    Use black or chrome door edge guard found your local parts store. The plastic chrome doesn't like tight bends.
  11. You can help it go around reasonably tight bends with a heat gun.
  12. chopolds
    chopolds
    from howell, nj
    Yup, this is it! Have ordered rubber for fender skirts, connie kits, tail light housings, and many other uses, they have a big selection of shapes and sizes.
  13. HOTRODPRIMER
    HOTRODPRIMER
    I have used vacuum hose in the past & is available in a variety of sizes and easy to cut with a single edge razor blade. HRP
  14. 5window
    5window
  15. donno
    donno
    X2 on the door edge trim.
  16. nickleone
    nickleone
    Steele Rubber.
    More rubber products than you can shake a stick at.
    Nick
